Exhaust smell
My 85 Carrera runs great and always passes smog. My question is why do air cooled Porsche cars smell so bad with their exhaust? More so when it is warming up. I have owned several VW bugs over the years and they seem to smell more that regular cars also. Is it because of the much hotter engines?
muck-raker
smells like Chanel No. 5 to me.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Member 911 Anonymous
There is No Substitute o\__/o
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Unless you have dead animal remnants up your pipe , that is what old cars smell like. Some even smell of petrol and oil and sweat. It's a manly odour for a manly car!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
1984 Porsche Carrera
I have a similar issue I suspect if you have has any oil leaks at any stage that haven't been completely removed they burn of while the car is idling
No, it's the great smell that is a mix of oil, gas, leather. This is the smell of the exhaust. Very strong at first, then gets better as the car warms up. Other cars don't seem to have this smell. I guess it's just the old air cooled smell!
Well when cold , it is in a rich mixture mode, once warm she leans out and disapates the sweet smell via the cat, wait you do have a cat, right?
Enjoy--it will never go away
----------------------------- Ernie 81 SC |
RETIRED
Better than 32 virgins.....but then I would be dead.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Undocumented User
if you're lucky, after a hard drive you'll be able to smell it on your clothes.
Go-Kart Mozart
That gasoline smell...the smell of victory.
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
It's because the exhaust is shorter, with a 911 your nose is just closer to the combustion chambers.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!) '11 Cayenne Manual, as in it has a clutch :-) (daily driver) '97 BMW Z3 (wife's ride) |
Got it! I just notice that Old VW's have a similar smell. So.....the air-cooled thing.
muck-raker
No, there is no substitute. But I'll take these in a pinch ( * )( * )
Senior Advisor
small holes can sometimes form in the header pipes, that leaks into the heat boxes. I had a couple of them CO2 detectors for aircraft that change color when they detect XX amount of CO2, put it in and the first drive it turned black as coal, i tossed it out, rolled the windows down a bit.
08 Cayenne Turbo |
It's true, old 911 can be smelly sometimes.
1985 911 Targa (sold) 2001 996 Twin Turbo (sold) 2001 996 C4 |
Driver, not Mechanic
I did put some Zeolite to remove some of the lingering smell... seemed to help. |
Go-Kart Mozart
I don't get the smells in the car though, just a little whiff backing out of the garage when the car is cold. At least not any more. When I bought the car the shift shaft seal on the trans was seaping and both of the trans to body seals were gone. Whole car smelled very strongly of Swepco. That got old quick. As soon as I replaced all the seals the smell dissipated. -J
