Dyno sheet finally made it to my laptop.
Science is NOT optional
very little clutter...that's how i would like my dyno sheet to look too.
PCA member since 1993 |
Ok, now you have to give us the full specs of this engine.
What heads is this running? What Cams? Details on the COP? Also interested, did you take a reference off the cam for timing?
Steven 1995 - 993 RS Tribute - 4.0l Engine plus other stuff... 2005 - Touareg V8 Tow Vehicle |
Engine specs
This engine runs DTA S60 engine management, wasted spark, no sync. sensor.
Bosch TPS used as load sensor MAP sensor for baro comp Bosch air temp sensor 993 RS flywheel 60-2 with 993 Bosch reference sensor Four 3 channel ignitors Omega high comp. pistons Elgin cams Proprietary cast aluminum heads Proprietary 2 pin connector COP Intake uses Early RSR plug hold down tabs Exhaust uses no hold downs, COP screws onto the plug, tops push on like stock ones Rothsport stainless headers with our own design v-band secured connector pipe GT 3 Cup muffler with factory engine bracket and straps We have another build like this engine in a 964 that has slides with our own design screw in stacks that makes 436 hp. This one is wasted spark also. ![]() ![]()
Andreas
1995 993 Coupe, Polar Silver / Black 2014 Audi A4, Monsoon Gray / Black 2002 Toyota 4Runner, Dorado Gold 2001 Toyota 4Runner, Dorado Gold, 604,XXX 1-owner miles 1998 Toyota 4Runner, Oxidized, 5-speed |
More intake options
Rothsport GT3 carbon intake. It weighs 6 lbs. compared to the metal factory @ 12 lb.
Now all we need is a sound clip of her running
Fancy stuff, wish I was rich
'73 2.0 914 (2.8 /6 conversion in progress) '64 356SC '65 Ducati Falcon 80 ‘19 Audi SQ5 |
Sound clip
OK...this was our first prototype 3.9 engine for Jeff's RSR on the slide valve system, and air filter setup.. We have about 40 more horsepower now, with newer engine management and quite a few new developments. The exhaust turn outs are to meet the 103 db limit at the local track where we test.
Rothsport Racing '97 Porsche 993 RSR Strafing Runs - YouTube |
Andy Bullen
oh my .....
76 912E - Grocery Getter 04 Toyota TacomaTRD - Beater Truck 08 Honda OdysseyEXL - Family Hauler |
Road test
It is even more amazing when you are there live!
Scotty, does the car in the video have the gt3 cup exhaust?
Exhaust
No, this engine had the Magnaflow muffler and older version headers we used in the past. Our new headers and GT3 muffler are on the car now.
Dyno video 3.9 435hp Rothsport Slide Valve
Rothsport 3.8 Yellow 993 ENGINE DYNO
Oh chit! I want one, but of course would have to sell all the Enron stock.......oh wait never mind.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
wow wow wow
I see in this pic of the exhaust there's a massive gap between the valve covers and the exhaust - is that to increase cooling/decrease exhaust to valve transfer? Is that possible in a NB car or only cos you have those mamma hips on the GT2 body? Or am I wrong and there isn't much to worry about from the collector pipe to valve covers/ig wires, and you just did that for the size of the GT3 muffler? |
That engine was one of our early builds a few years back. We are using our own design headers now and we do use a heat shield to protect the valve cover and coil on plugs.
super thanks for that - do you sell those headers/exhausts?
