Firewall foam
Cleaning up some wires, etc. and the foam "blocks" behind the shock towers is just crumbling. Can't figure out where it is in PP catalog, or maybe it's NLA. What does everyone else use?
Todd
'81 SC |
Search for 'engine sound pad' and you'll see a few options.
Not the sound pad. Square "blocks" that stuff where the wire harness passes to the bottom.
Todd
'81 SC |
Chief Head Scratcher
The foam blocks are 911.504.930.00
They look to be available still for $23.50 each. I'm sure that someone must have found a good substitute...
John Morris '79 911SC Last edited by kerthunk; 05-26-2013 at 12:10 PM.. |
Taking it apart is easy
If you need only the original type part, I can't help you.
However, dense foam that is used to cushion vibration and noise (such as the material sold to isolate window air-conditioners) is not expensive, and it can be cut to suit the shape of the gap/hole you are trying to fill. I used this material in my car.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
note: Food for thought, any kind of foam regardless of density is a fire hazard that is easily ignited; think carefully before using it in different applications especially around electrical wiring and components regardless of voltage
^^ Good thought, but was the original foam Porsche used fireproof?
Retired Member
I removed the foam blocks over 5 years ago and never replaced them. I've never had an issue without having them in place.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Banned
Links to past threads on the subject - Do you guy's know what these are? Last edited by Ronnie's.930; 05-26-2013 at 10:55 PM.. |
