toddu's Avatar
Firewall foam
Cleaning up some wires, etc. and the foam "blocks" behind the shock towers is just crumbling. Can't figure out where it is in PP catalog, or maybe it's NLA. What does everyone else use?
Todd
'81 SC
Old 05-26-2013, 07:42 AM
OttawaDave's Avatar
Search for 'engine sound pad' and you'll see a few options.
Old 05-26-2013, 07:59 AM
toddu's Avatar
Not the sound pad. Square "blocks" that stuff where the wire harness passes to the bottom.
Todd
'81 SC
Old 05-26-2013, 11:55 AM
Chief Head Scratcher
kerthunk's Avatar
The foam blocks are 911.504.930.00
They look to be available still for $23.50 each. I'm sure that someone must have found a good substitute...
John Morris
'79 911SC
Old 05-26-2013, 12:08 PM
Taking it apart is easy
Jerome74911S's Avatar
If you need only the original type part, I can't help you.
However, dense foam that is used to cushion vibration and noise (such as the material sold to isolate window air-conditioners) is not expensive, and it can be cut to suit the shape of the gap/hole you are trying to fill.
I used this material in my car.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-26-2013, 12:10 PM
note: Food for thought, any kind of foam regardless of density is a fire hazard that is easily ignited; think carefully before using it in different applications especially around electrical wiring and components regardless of voltage
Old 05-26-2013, 01:43 PM
^^ Good thought, but was the original foam Porsche used fireproof?
Jerome
Old 05-26-2013, 03:39 PM
Retired Member
Brian 162's Avatar
I removed the foam blocks over 5 years ago and never replaced them. I've never had an issue without having them in place.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 05-26-2013, 05:48 PM
Banned
Todd
The foam blocks are there to help prevent hot air and dirt, from beneath the car, from entering the engine bay via the engine fan - it is a good idea to have them, or a suitable substitute, in place.
Links to past threads on the subject -
Do you guy's know what these are?
Old 05-26-2013, 06:32 PM
