Help identifying my front brake calipers - potential Boxter upgrade?
Car is a 1974 911, but keep in mind this car has parts changed from many other years. No booster.
Going through my build, I noticed that the previous owner had replaced the driver side caliper that is different than the passenger side. Also noticed that the previous owner installed drilled rotors but one side the holes are going the wrong way. All this coupled with a seized rear left caliper means a full brake system overhaul. ![]() ![]() Can anyone identify the calipers on this car? all rotors on the car are 20mm. I am thinking about rebuilding the rear calipers and leave them stock. Then run Boxter (986) front brakes, and upgrade to 24mm Carrera rotors. Would this setup work fine with my stock '74 non boosted master cylinder? I keep reading about people switching to the 930 master cylinder but I would like to avoid it if possible. Anyone who has done this before - I would love your input. Thanks. |
LHS looks like an S alloy caliper and the RHS looks like an M or A type cast iron caliper. Measure the distance between the caliper mounting bolts to be sure
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
Would the S calipers measure out different than the cast iron ones? I know theres 3 inch and 3.5 inch ear spacing just not sure which calipers have which.
![]() Definitely an S ![]() Both A & S have 3.5 mounts If it was my car i'd buy another to match one of those If you use Boxster fronts then you want 3.2 Carrera rear, no p/v
Since the S is newer I will likely try and look for an S brake for the passenger side. Boxter caliper is more for cool factor but I am unsure if its worth the headache for marginal performance in a street car. |
Both S and A calipers have 3.5 inch spacing and M calipers are 3 inch. You will find it easier to replace the A caliper if that's what it is. I would measure the mount bolt spacing to be sure because whoever fitted the odd caliper has already proven they are short a few spanners in the mechanical department and may have swapped in an entire strut and M caliper. (but it does look like an A caliper, the pads are larger and are the same size in the S and the A caliper, the M pads are smaller.)
Cool. Looks like they are both 3.5 inches.
All the callipers need a rebuild anyway - so my plan is to replace the fronts with the late model Carrera 3.2 front callipers (I think they are referred to as "Wide A"?) and corrosponding 24mm thick rotors. From what I have read that -should- just bolt up and work with my current setup and offer slightly more heat dissipation. Then just rebuild the rears. I can find these late model callipers easily at the local parts places. Not so much for the original S calipers. |
83 911 Production Cab #10
All the one that PP sell are the same disk for the left or right event Sebro Pair package got the same pattern on both disks. I think that one I came across a supplier that had one part # for the left and a different one for the right. I would think if Porsche had some on the Turbo, it would have mirror patter on them. Maybe Bill can shed some light on this. ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Cars and Cappuccino
Curious what others think about a Carrera brake upgrade with no booster. I am thinking the same route for my current build and also thinking you may want to upgrade the master cylinder to the bigger bore version.
Bill V or anyone else care to chime in?
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
From my research it would bolt up and just work. Carrera calipers have the same piston size but just use 24mm thick rotors. If I end up going this route I'll let you know if it works out.
