Guest
Posts: n/a
I ordered front and rear rotors for my 1986 Porsche 911. I read your article and had no difficulty replaacing the back rotors. Thanks for wonderful article. I am having difficulty taking out the front rotors. I am at a loss and would need your help
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing Brake Pads - 911 (1965-89) - 930 Turbo (1975-89) |
Without knowing exactly what the problem is I can only assume you cannot get the retaining screw out because it is seized or the center of the rotor is seized onto the hub. Use penetrating oil and let is soak for a few hours then tap them off with a hammer.
- Nick |
