Re 1972 911: My flasher relay which operates the blinker, hazard, hand brake warning, is making the clicking sound but no lights are blinking on the dash or outside the car. Any idea? I suspect a short to ground somewhere in the 40 yr old wiring. Where should I start?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Troubleshooting Electrical Problems - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-28-2013, 04:41 PM
Nick at Pelican Parts's Avatar
Follow the wiring leaving the flasher relay. Since all your lights are out the broken wire must be before it starts branching out to the rest of the car. If you had a short the fuse would blow first
- Nick
bill's911's Avatar
My 88 Targa is the opposite ... Indicator lights inside and outside working great but no clicking. I can live with it, but will likely look for a solution.
Bill
Old 05-28-2013, 05:54 PM
Send a message via Skype™ to Porboynz
Fuses 9 and 10 OK then?
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 05-29-2013, 01:33 AM
E Sully's Avatar
The description is a little vague. Does it make the clicking all the time, even when not using the flashers or directionals? Or does it only make the sound when directionals and, or flashers are used. Does the parking brake light come on when you lift the handle?
This is the wiring for the brake system.
Ed
1973.5 T
Old 05-29-2013, 08:09 AM
