RE: 1980 SC Caliper Rebuild Advice
I am rebuilding the the front and rear calipers on my 80 SC and noticed the original pistons are pitted which seems like normal wear....should I replace them with stainless pistons and if so, which ones? Any other recommendations for the job?
1986 944 Racecar
2000 Boxster ClubSport
Old 05-30-2013, 06:23 AM
I'd send them to Eric Shea at PMB and be done with it... Much better than just a rebuild.
JR
Old 05-30-2013, 06:25 AM
Eng-o-neer
Tremelune's Avatar
Unless you're rebuilding them for fun, go with PMB. Excellent work over there. They send you a restored set right away, and then refund you the core charge when you ship your old calipers to them.
To quote Eric: "Stainless pistons are available at $39.00 but I feel that, unless you really need them, there is no advantage in getting them. We vibratory polish all of the pistons and re-coat them with a factory grey heat coating."
Old 05-30-2013, 02:02 PM
Speed Dog's Chauffeur
Dodge Man's Avatar
2nd & 3rd PMB
2nd & 3rd PMB
Go with Eric at PMB and save yourself a lot of grief and $$ in the long run. He also has the nice brake pads to go with your fresh calipers too. My PMBs & Pads "ROCK" !
Old 05-30-2013, 05:41 PM
ADDvanced's Avatar
A lot of grief? I just rebuilt my front caliper. It cost $5 for the rebuild kit. It took a while to get one of the pistons out (seized), but then I polished them and slapped them together in 30 minutes. Not too bad for $5.
Old 05-30-2013, 05:43 PM
ganun's Avatar
If one is stuck, put a big C clamp on the good one so it wont move a connect the hydraulics to it and have someone gently step on the brakes. Hydraulic pressure will do the hard work. Clean the seal groove really well , bent dentists pick -and only used new fluid to lubricate the seal, a ATE break grease on the piston and backside of the dust cover and your go to go
Old 05-30-2013, 05:53 PM
SchnellSchweitz's Avatar
The safest way I found to remove a stuck piston is with a grease gun and a zert for the bleeders. Hopefully, you don't need it but that was the only way I could safely remove one of mine.
You can clean it up with a little rubbing alcohol, Q-tips and a Handyvac helps to suck the alcohol back through the bleeders.
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 05-30-2013, 07:30 PM
