Quick Question RE tightening fan belt
I need to do this immediately, as tool just arrived. To make belt tighter, I have to take shim from inside and put it on outside, correct?
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Ruby911
Correct.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
4 in, 1 out made it right.
Member 911 Anonymous
It depends, oem belt 3 in 3 out, new.
Conti belt, 1 in 5 out. It appears you are missing a shim.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Bentley says you should be able to move the belt 10-15mm at the midpoint between the two pulleys. Remember, it won't reach full tension until you torque that bolt.
I thought it was supposed to be 5 total. I had 6 but took one off.
ROW '78 911 Targa
6 is correct , if you use less you can mess up the shoulder for the nut and then get to post in the Damn it thread...
Thanks for all the replies. Anyone know why Wayne says 5 in his book?
RETIRED
There are a few items in the book that are considered to be not the norm. Six is the norm.....also you can go thru the dash ports after removing gauges to move the wipers to the passenger side park position.
Bentley has some glaring errors.....but Wayne's is more or less correct. You could email Wayne and ask why he recomends 5 shims.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 06-01-2013 at 07:47 AM.. |
Always wondered how to do the passenger side wiper park.
RETIRED
There are more than a few threads on it. Pull the clock and the gauge to the left. Using a strong flashlight locate the wiper motor and arm.
Pull the nut, relocate the wipers to the passenger parked location, tighten down and test. There are a few gotchas that are recommended.....do a search. I did it a few years ago....I used a single longer reachvwiper for awhile. Didn't like it. I went back to a dual....ask Draco how that worked out....%^)
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 06-01-2013 at 08:28 AM.. |
