Can I re-use the pedal cluster Roll Pins?
Before you think I am a cheap skate, these things are apparently made of unobtainium.
I ordered these while rebuilding the pedal cluster, and just found out that they haven't been received yet (by the shipper). (Work was necessitated by a need to replace the tunnel fuel lines, and oh by the way, some bushings were shot). Other things seem to indicate I could be in for a long wait (not available elsewhere, etc). I will try a dealer in the morning but just in case, I was wondering if these items could be reused? I did not drill them out, I used a 4mm punch (per the 101 project book). As you may know, they are made of spring steel. This is a G50, and the clutch pedal shaft is in good shape especially in the vicinity of the holes. I have spent a few hundred in material, and some hours of sweat equity (albeit quite therapeutic for me and the car) - all to be held up by 3x 2 dollar parts. ![]() many thanks
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Not positive of the orientation but could you start the old pin out (in situ) with a punch and once started drive it the rest of the way out with the new pin? If so id use the old one till then.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I did the pedal assembly in my 87, they looked good so I reused them. NP
I also did the tunnel fuel nines and what a PITA.
ganun - you are the man. Thanks very much.
I will still try locally, but it is great news to know that I can drive on and re-use/re-cycle if they are un-obtainable... and replace if and when the order is fulfilled (maybe). Amen brother on the Pita / tunnel lines. The effort is actually a pain in the neck LOL, but for thr peace of mind I don't mind tackling it. I have however gone father than I expected (new clutch MC, and the obligatory line and slave cyl). Builds character as they say. It actually started when I dropped the rear sway while I was in there doing the rear TB bushings (if you can believe it) ![]() PS - nice paint job! Pete3799 - sorry if I misled - removal was easier than ordering them. I have the originals out already, cannot get replacements to satisfy my impatience, and was questioning if I would be committing an unsafe/unwise act by being green (re-using the originals because I can't get any online, and have no confidence in a delivery date). ![]() sorry for upside down cam pic - looked ok when I loaded it. (smart fone noob)
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 05-30-2013 at 06:48 PM.. |
Banned
Dan, there are pedal bushing kits on eBay that have the roll pin in them (a guy on the 930 forum just got a kit from there). I bet there is a chance the seller would sell just the pin(s).
