2.7 Engine Noise
Weird. Looks like some screw has worked its way loose. Notice the flame. I want to use the car this weekend. Can i temporarily stick any screw that fits in there before getting the right part? Is there a concern with the screw going too deep?
Here is a photo.
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html |
Nice light show, that cannot be good.
I have no idea, but will give you a free BUMP. Now I have one more thing to look out for.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
One of you plugs for secondary air injection ports blew out. Pelican has them under PEL-BRC-02 Porsche 911 & Turbo CIS Fuel Injection - Page 13
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
Air injection port in exhaust outlet, put a screw back in!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
SWEET! Thanks for the help. And only $3! Can I put something temporary in there for my weekend trip? Any concerns about going deep with the screw?
port
Interesting so is it a set screw? Air injection port that leads to combustion chamber ?
K
Ken - ebay: wandrey1 , *0 , *00 , *01 74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3 81 VW Caddy Pickup X2 now... 84,85x2 .86,87,944. 82-924,88-924s parted with inventory! 68, 70, 72, 73, 911~ 70,73 914 past P/cars |
I got this response on another thread
Most have removed the plumbing ! Part 15 is now a short screw plug
non-whiner
It's a metric plug. You should be able to find one at a well stocked hardware or auto parts store.
"Too much is just enough." |
Fantastic, you guys are the best. I tried some screws that are laying around to no avail. I'll get a range of plugs tomorrow and hope for the best.
BTW, the other plug are a square fitting. How annoying are those to take out?!?
Small spanner , take one bolt out and take to the hardware store.
I believe a 12 point socket will work on a square head.
Chris '75 911s Targa |
No luck. I tried a number of different ones. They aren't in clean perfectly square shape to begin with, couldn't get a good grip. I'll get an array of bolts and hope for the best. Wish me luck.
Try M8x20mm
Tazzie, thanks for the help. Really appreciate it.
If it is M8 I'll have a problem. I tried an M8 and an M10 last night. M10 too big, M8 Just too small. I hope this doesn't mean the threads have been stripped. I may have to retap the hole.
It's a strange size. I couldn't find anything that would fit at the hardware store. I believe the plug that PP sells also fits a 914 brake caliper allen bolt adjustment port.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
10mm fine thread, get it at Lowes
Bruce |
Flat6pac, thanks for the reference. That is exactly what I got...well, honestly, I bought a range of sizes just in case, turns out it was M10 x 1.25 x 20. It fit perfectly. Tightened it up and took the car for a spin. Nice and quiet, drove like a charm. Thanks again for the help! I purchased the original parts from PP but this will do for now.
There it is on the right.
