Forum noob - my '88 JDM 3.2
Hey gang, just a quick note to introduce myself and intro my latest addition to the stable. I just picked up a very nice '88 Carrera with a mere 97,000 km on the odometer. Originally a Japanese car, it came over to Canada in 2006 and I'm the 3rd owner since it arrived here. Lacking any records from her days in Japan, but passed a PPI/compression test with flying colours. And no leaks!! I have already run into one small issue, though, and that's some bucking/stuttering under heavy throttle between 3000-4500 RPM - it's intermittent, but I haven't been able to narrow down conditions just yet. Gives me something to work on right away
I look forward to getting more involved with the excellent group here on PP - been a Mini/BMW guy for many years now, but I've finally realized my life-long dream of an 80's 911 (silver with black Fuchs and a whale tail, of course).
Pleased to make your acquaintance!
Old 05-19-2013, 02:54 PM
Nice car! I am another recent member of the 911 fraternity. Mine is also a Japanese 911 but it's an '86. It also came to Canada in 2006. Enjoy!
Cheers
Colin
1986 Carrera 3.2
Old 05-19-2013, 03:05 PM
db_cooper's Avatar
Super nice 911..congratulations.
One thing about low milage 911s..they sat a lot. Condensation in the steel fuel tank is very normal, so when they sit in the garage for extended period of time some rust will develop.
Your intermittent running issue could be a clogged filter screen in the bottom of the fuel tank. Parts are about $50 from our host. Part number 911-201-141-00-M100
The filter is not an maintenance item..it should be replaced every couple of decades.
Replace the "O" ring at the bottom too. Part number 911-201-143-00-M100
I would go ahead and do a full service on the car for peace of mind. All new filters, engine oil, valve adjustment, cap and rotor, gearbox oil, change brake fluid and spark plugs. Change the brake fluid too and check the pads and rotors.
Enjoy your car for many years.
Old 05-19-2013, 03:48 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Welcome Aboard!
Before the fuel tank filter, try replacing the fuel filter or run some BG44K thru a full tank.
Also suggest having a spare DME relay, just in case DME is ready to go which control the fuel pump via the DME/ECU.
'85 Carrera Targa
PCA/POC
Old 05-19-2013, 04:19 PM
SansEau
Welcome to the club! I bought a Jdm about 4 years back with 113,000 clicks on odo. Did the same PPI and it came back good. It has been very good to me since then. I've done some tinkering and installed a SW chip. It rocks! I like the fact that the JDMs have the fully leather seat in the back. That is unique to the Japan delivered Porsches. The euro rear bumper treatment is also nice.
enjoy!
Old 05-19-2013, 04:55 PM
m110's Avatar
Excellent, welcome, is it RHD?
search motronic stumbling and you'll find plenty. flapper door, sensors, fuel filters, cap and rotor, DME. But once you get it going it is very rewarding.
That's pretty low miles.
1988 Carrera Coupe
Old 05-19-2013, 05:46 PM
Thanks to all for your recommendations! I'm thinking the fuel filter or some BG44K might be the first step, followed by the tank filter. db_cooper makes a good point about low mileage cars doing a lot of sitting, so I'm sure there's a good chance of sediment in the tank. Again, the funny thing is that it's intermittent - came back from a far away place today (about 600km) and no stumbling to be found.
- already got a replacement DME relay in the glovebox
- last oil change was September, but I'll likely do another within the next 4-5 weeks
- valves also done last September
- cap, rotor, and plugs all have about 2500 km on them
m110, the car is not RHD - funny that it's destined for the Japanese market, but still LHD. Does anyone know if any 911's for Japan were right-hand-drive?
1988 JDM Carrera 3.2, cat delete, Fabspeed exhaust, Euromeister replicas (Fuchs in the garage). LOVE IT!
Old 05-20-2013, 04:36 PM
oh snap's Avatar
There are some RHD 911s in Japan but the vast majority seem to be left handles.
Im not sure if they were usually not offered as RHD cars or if most just ordered LHD cars because they are "cooler"
Great car. Does your car have the "unusual" Japan spec rear seats? They have a cushion that extends across the middle "hump."
Otherwise I believe your car should be basically euro spec. A little extra power over the NA cars. Enjoy!
1985 Iris Blue M491 911 Coupe
Old 05-20-2013, 06:00 PM
Weseeeee911
Nice car! I've always liked Silver p-cars.
Al
80SC 95-present
Old 05-20-2013, 06:33 PM
Nice car!
I love these silver coupes!
Old 05-20-2013, 06:58 PM
Very nice silver coupe. Wider Fuchs also. I can't tell from the pic, is it a sunroof delete model? Also, iirc the Japanese spec cars had a similar specification engine as the US spec cars.
Old 05-21-2013, 05:07 AM
dshepp806's Avatar
Very nice! Congrats! Run the BG then change out the fuel filter. ...then oil. As to Gas Tank filter,..go for it. I checked/changed mine years ago and found a crystal clean filter. Changed it out and sent the old one to an Aussie friend who direly needed it/ Of course, she wasn't a garage queen.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-21-2013, 04:30 PM
CMA CMA is offline
Great car! If that's the one I think it is, from the Burlington Area. I saw it last year and it shows well. The past PO took great care of it.
Congrats!
Old 05-21-2013, 06:16 PM
TheMentat's Avatar
I think I have the exact same car as you! Silver, '88 JDM, no sunroof coupe!
I had a similar issue to what you described... It only seemed to act up when the car was cold. If I recall, I resolved it with a new cylinder head temperature sensor, but I'll check my notes.
Congrats!
Old 05-21-2013, 08:39 PM
Cheers, guys - yah, I'm so excited to have this in my stable! From what I've read, engine specs for the Japanese cars are identical to North American cars, so no Euro HP, unfortunately.
No sunroof delete - this is a genuine coupe!
For the South-Western Ontario area people, where do you find BG products? Would Sea Foam be just as good?
CMA, good eye! The car did indeed come from a guy in Burlington who was also trying to sell last fall.
TheMentat, maybe a road trip to BC is in order and we can introduce the twins
Old 05-31-2013, 05:39 AM
Eva
911SauCy's Avatar
So I'm dying to know...is that Camaro an SS? Is it yours?
My family has mid-late 90s F-Body's and I know how they drive...I haven't driven a late model but they look, weigh, and seemingly handle like trucks?
Is this a safe assumption in comparison to the 911?
Am I way off in left field?
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-31-2013, 06:07 AM
Smoove1010
Smoove1010's Avatar
Congrats! So, two cool cars in the driveway? What's hiding in the garage?
Good luck!
GK
Old 05-31-2013, 07:16 AM
