NeedSpace's Avatar
2.7 Engine Noise
Weird. Looks like some screw has worked its way loose. Notice the flame. I want to use the car this weekend. Can i temporarily stick any screw that fits in there before getting the right part? Is there a concern with the screw going too deep?
Here is a photo.
Old 05-30-2013, 05:34 PM
Nice light show, that cannot be good.
I have no idea, but will give you a free BUMP.
Now I have one more thing to look out for.
Old 05-30-2013, 05:46 PM
howard freeman's Avatar
One of you plugs for secondary air injection ports blew out. Pelican has them under PEL-BRC-02 Porsche 911 & Turbo CIS Fuel Injection - Page 13
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 05-30-2013, 05:49 PM
tazzieman's Avatar
Air injection port in exhaust outlet, put a screw back in!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
NeedSpace's Avatar
SWEET! Thanks for the help. And only $3! Can I put something temporary in there for my weekend trip? Any concerns about going deep with the screw?
Old 05-30-2013, 05:54 PM
kens_74_911s's Avatar
port
Interesting so is it a set screw? Air injection port that leads to combustion chamber ?
K
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 05-30-2013, 06:04 PM
NeedSpace's Avatar
I got this response on another thread
Originally Posted by sonett43 View Post
Useless indeed....these cars originally had an air injection system/pump, in order to limits te the air injection you would cap the heads where the injector attached.
Old 05-30-2013, 06:12 PM
tazzieman's Avatar
Most have removed the plumbing ! Part 15 is now a short screw plug
Old 05-30-2013, 06:32 PM
non-whiner
mreid's Avatar
It's a metric plug. You should be able to find one at a well stocked hardware or auto parts store.
"Too much is just enough."
Old 05-30-2013, 06:40 PM
NeedSpace's Avatar
Fantastic, you guys are the best. I tried some screws that are laying around to no avail. I'll get a range of plugs tomorrow and hope for the best.
BTW, the other plug are a square fitting. How annoying are those to take out?!?
Old 05-30-2013, 06:45 PM
tazzieman's Avatar
Small spanner , take one bolt out and take to the hardware store.
Old 05-30-2013, 06:54 PM
I believe a 12 point socket will work on a square head.
Chris
'75 911s Targa
Old 05-30-2013, 08:12 PM
NeedSpace's Avatar
No luck. I tried a number of different ones. They aren't in clean perfectly square shape to begin with, couldn't get a good grip. I'll get an array of bolts and hope for the best. Wish me luck.
Old 05-30-2013, 08:47 PM
tazzieman's Avatar
Try M8x20mm
Old 05-30-2013, 09:06 PM
NeedSpace's Avatar
Tazzie, thanks for the help. Really appreciate it.
If it is M8 I'll have a problem. I tried an M8 and an M10 last night. M10 too big, M8 Just too small. I hope this doesn't mean the threads have been stripped. I may have to retap the hole.
Old 05-31-2013, 07:03 AM
kodioneill's Avatar
It's a strange size. I couldn't find anything that would fit at the hardware store. I believe the plug that PP sells also fits a 914 brake caliper allen bolt adjustment port.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-31-2013, 07:42 AM
10mm fine thread, get it at Lowes
Bruce
Old 05-31-2013, 10:23 AM
NeedSpace's Avatar
Flat6pac, thanks for the reference. That is exactly what I got...well, honestly, I bought a range of sizes just in case, turns out it was M10 x 1.25 x 20. It fit perfectly. Tightened it up and took the car for a spin. Nice and quiet, drove like a charm. Thanks again for the help! I purchased the original parts from PP but this will do for now.
There it is on the right.
Old 05-31-2013, 05:42 PM
