Anyone use torque sticks with an impact wrench?
Torque Sticks, Torque Sockets and Other Discount Tools
Wondering if any one out there uses these torque sticks with an impact wrench. Also, our cars call for 94 ft lbs. is 100 ft lbs too much? They only come in 10 ft lbs increments... Thanks for the help!
Dave Black 1985 911 Carrera M491 |
Maybe I'm wrong, but I was told not to use impact gun on aluminum nuts, it will crack them. I use torque sticks all the time on steel nuts at work, but not aluminum.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
Banned
I've used impact guns on aluminum nuts for over 25 years and never cracked one, however, I always finish tightening them with a torque wrench. I've never use a torque stick . . .
petercory
If you own a Torque Wrench why resort to using a Torque Stick?
I have one, it seems to function as intended. If you are going to torque your lugs with an impact driver/wrench it is a decent way to avoid getting the torque wrench out. I can also see it as being handy at the track to avoid bringing an additional tool. I don't really use mine anymore because it doesn't fit inside the recesses of my cup1 wheels. PM me if you are interested in it.
Forgot to mention it is a 19mm/100ft pound stick. Torque spec on the lugs is 96 ft. pounds.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) Last edited by Justin@Athens; 06-01-2013 at 06:19 PM.. Reason: addtl info |
A flat rate technician will tell you he doesn't have time to use a torque wrench 20 times on each tire rotation.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
