Recreational User
porschenut's Avatar
Originally Posted by T77911S View Post
when i saw that you did that in your other post i did not think that was a good idea.
i have always blead the MC on the car. actually never heard of doing it on the bench.
i just crack the lines at the MC to bleed it, then do it at the wheels. another thing, and i think you may have done this, is to wait a week or so then bleed them again.
what type of fluid are you using? DOT?
ATE Gold and Super Blue after making sure I have a good pedal. I don't waste that stuff while bleeding the first time through. But as I said, I do not bleed the MC and I haven't had a problem. There are past threads on the subject and a lot of discussion. Some feel it's worthwhile, others don't.
Old 06-07-2013, 10:05 AM
Originally Posted by Ronnie's.930 View Post
But would your pedal sink to the floorboard like the OP's does?
yes it did. thats why I replaced the m/c but had the same results. It was very strange. You could actually see the pads squishing. My brother has been a mechanic for 15 years and has never seen it before
Old 06-07-2013, 04:10 PM
MConn's Avatar
Someone here on the PP forum (Walker?)has talked about a trick with rebuilt calipers - that you take out the new pads and put in old pads, or something that will allow the caliper piston to extend out, then bleed the calipers, then install the new pads.
Mike
The more I learn, the less I know.
Old 06-07-2013, 04:56 PM
Mike
Yup did that on mine and did notice a difference (even with my crappy MC).
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 06-07-2013, 06:27 PM
Charles Freeborn's Avatar
Sounds like you may have a dud MC. It happens. They can leak internally. Pelican will make it right.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 06-07-2013, 06:38 PM
Mr9146's Avatar
Recently I have encountered two brand new ATE master cylinders that were bad right out of the box. Both presented with the exact same symptoms as yours; no amount of bleeding would correct it. Swapped them out with another new ATE replacement and the problem was solved.
There seems to have been a run of bad masters out of the ATE factory.
Old 06-07-2013, 08:37 PM
