A/C delete foot board question
85 ROW 3.2 RHD Drive Car
I have just removed the a/c compressor (or is it condensor) from behind the p/x foot board. Can I now use the non a/c footboard to give the px more foot room?
It was a tough decision to remove a/c, but now I know how heavy it all is I feel a lot better.
Ed
Old 06-10-2013, 03:00 PM
The evaporator you mean? You want to have your passenger put their feet in the little hole? Otherwise, why would you remove it in regards to interior space?
Old 06-10-2013, 03:31 PM
tazzieman's Avatar
You realise it's RHD?
You can use whatever you like to give your passenger more room!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 06-10-2013, 03:41 PM
Well then that's even more confusing. RHD cars have a much tighter pedal area I imagine. I would disagree with the "use whatever you like" statement though. I think the front bulkhead is rather fixed.
Old 06-10-2013, 03:46 PM
wwest's Avatar
Ed
The same fb is used A/C or non...I suspect you're looking at some aftermarket A/C product.
Old 06-10-2013, 03:47 PM
RHD drive cars the evaportor is behind the foot board on the px side. If you look at rennline for RHD cars there are two boards. One with a/c and one without.
I want to set the board further towards the front of the car to give more room (now the evaportator isnt in the way).
Can this be done?
Ed
Old 06-10-2013, 04:12 PM
Reiver
Reiver's Avatar
there is no real reason to put the wooden floorboard back in place if you choose not to.
Old 06-10-2013, 04:26 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Ed,
Can you demonstrate with pictures or diagrams where the space savings would be?
The piece of wood has no buffer towards the front, correct? It sits on the metal tub in some tabs held in place with a screw/grommet/washer/spacer thing.
The hole can open up for a six year old's little tiny feet.
1981 911SC Targa
Old 06-10-2013, 05:07 PM
