Did SC's have a factory "Buzzer"?
While I was under the dash of my '82 SC installing a new ignition switch, I noticed that the source of the annoying 10 seconds of buzzing every time I started the car was an after market buzzer box. A PO had spliced this thing in to the run signals from the ignition switch, and the key-in-ignition sensor. I removed it, because the added-in wiring was not done well, and I never cared for the buzzing.
Did the car originally have a buzzer that this was installed to replace, or did this guy just really love a the sounds of a buzzer?
What was the key-in-ignition sensor was wired to before?
Max
1985 BMW 325e - 2 Door
1982 Porsche 911 SC Euro Spec
1965 Land Rover Series IIa Restoration Project
1999 Land Rover Discovery II
2002 Suzuki SV650 Naked Bike
Old 06-06-2013, 11:34 PM
D911SC's Avatar
Could it be related to seat belt warning?
I don't think this was around in 82 but if its after market then perhaps it was installed. Have you tried the ignition with th seat belts fastened?
I would also suggest low beam lighting but I think it would be less likely that you turn the lights on before the car is running.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 06-07-2013, 02:07 AM
I am my 911's PO
'78 SC's Avatar
Factory buzzer warns you the key is in the ignition. Opening either door triggers it. Sometimes there is a bit of a delay. Pulling the key out a bit stops it (stays off if key is pushed back in). Opening door with engine on also triggers it.
These were frequently disabled because the buzzer is so annoying. I tolerate it for the sake of originality.
Old 06-07-2013, 03:36 AM
El Duderino
tirwin's Avatar
Mine quit working about a year ago on my '83. I didn't notice it for a while so I'm not sure if it just died or if I did something accidentally while I was fixing something else. Have to say I don't miss it but that will only last until I do something stupid like leave the headlights on and drain the battery.
Old 06-07-2013, 04:47 AM
Recreational Mechanic
Nickshu's Avatar
US spec had a buzzer behind the gas gauge.
Yours may have been added as a requirement for importing a euro model as a seatbelt buzzer is a US federal requirement.
I unplugged mine years ago. Only consequence on a US model is the seatbelt light will no longer Illuminate with the relay unplugged.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 06-07-2013, 04:58 AM
Eva
911SauCy's Avatar
Yep. I think mine is a Union Member...works when it wants to....
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 06-08-2013, 07:06 AM
Nickshu's Avatar
On some of the later cars (86-on I think) the seatbelt buzzer was tied to the interior lights wiring so that if you disconnected it or it stopped working your interior dome lights would no longer function.
Old 06-08-2013, 07:12 AM
Recreational User
porschenut's Avatar
On both of my '86's and my '88, the dome lights function without the buzzer relay.
Old 06-08-2013, 11:43 AM
