DGriz's Avatar
1980 SC - idle "hunting" and stalling - Altitude?
I went to see a 1980 SC today with a buddy.
While the engine started fine, the idle began to "hunt"- going from idle to near stall and back.
This car has recently moved to Denver's 5280 altitude from Florida, and the seller says the fuel injection must need adjustment for altitude.
I drove it, and it stalled unless you kept the idle up....Is the seller's explanation ridiculous, or with merit?
Either way my buddy would get a PPI, but I had to ask.
Thanks - Dickson
Old 06-09-2013, 10:11 PM
SchnellSchweitz's Avatar
Sorry... was it equipped with an aftermarket electronic fuel injection or OEM delivery? You can usually tell by how the engine looks. OEM has the black plastic filter over and behind the fan. EFI usually looks pretty empty behind the fan. Often you will see modern fuel rails running from front to back on both top outer-edges of the motor. Did the owner mention megasquirt? There's a big difference in how issues are diagnosed for EFI.
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 06-09-2013, 10:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Vacuum leak.
'85 Carrera Targa
PCA/POC
Old 06-09-2013, 10:33 PM
T77911S's Avatar
WUR may not be getting power to warm up or it could be bad. anyway, fuel pressures need to be checked first or at the least it could just be lean from alt. if it is so simple, why did he not have it done if he is selling it?
i would count on the WUR being bad and have to completely go thru the CIS and replace things that leak air, like Orings, injector sleeves, rubber boots just to name a few.
i try to count on the worst when buying a car.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-10-2013, 04:56 AM
DGriz's Avatar
As far as I know the FI is stock but who knows. The car does have some track history and "race" mods like heavier suspension, upgraded brakes. We will see - but a PPI is a certainty.
Old 06-10-2013, 07:11 AM
It would be running rich if it went from FL to CO. It will idle hunt from running rich, and it will most certainly need an adjustment from being up here. It might have been out of adjustment in FL, and the thin air up here might just be making it worse.
That said - idle hunting is a symptom for a lot of problems.
88 Carrera - Venetian Blue
2002 Audi S4 Avant (KIA)
Old 06-10-2013, 07:18 AM
Reiver
Reiver's Avatar
Way too rich, re set the CO...very common if it was on the rich side at sea level it will be way to fat for that height
Old 06-10-2013, 07:51 AM
That's one of the problems with CIS injection, it's unable to compensate for changes in altitude effectively. From sea level to anything above 3500ft I would always have lean it out to regain performance on my 78 3.0.
Cheers,
Joe
Old 06-10-2013, 08:23 AM
Reiver
Reiver's Avatar
I don't have a problem if you balance it. I drive from Phx to about 5000 ft regularly without issue (9.8 comp).
Lots of folks have fattened the CO for cooler running and detonation safety with the higher compression numbered cars. Take that to a much higher altitude and it's just too rich at idle.
Old 06-10-2013, 08:45 AM
