wwest's Avatar
Correct Trinary Pressure Sensor/Switch
Red Dot P/N 71R7500, GM 35899
Open below 2.81 kg/39.9020
Open above 22.8 kg/323.7600
Fan on 8.4 kg/119.2800
Old 06-19-2013, 01:49 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Trinary II™ Switch Freightliner OEM# RD 5-4585-0
1981 911SC Targa
Old 06-19-2013, 01:54 PM
wwest's Avatar
Originally Posted by Bob Kontak View Post
Thanks.
Old 06-19-2013, 01:58 PM
Bob Kontak's Avatar
One does have to do some crafting to get that integrated?
Physical entry into the high side and clearly some wiring time to keep fan(s) on post shutdown and kill compressor if outside operation limits. Former is my concern. Latter just takes time to configure - my take/comfort level.
1981 911SC Targa
Old 06-19-2013, 02:10 PM
Bob Kontak's Avatar
Main thing I like is that high side over 325 means something ain't right.
2 times 120F = 240 + 50 = 290 psi. Rule of thumb, right? That gives an extra 35 psi before shutdown if idling in the sun on a hot day in Phonix.
Set aside theories and arguments. This makes sense. If your system is working fine, not needed. If not, then this protects your system/investment.
1981 911SC Targa
Old 06-19-2013, 02:37 PM
French Import
zippy_gg's Avatar
Good info and great timing for me as I need to get new hoses made.
I guess I need to add a "T" connector for the trinary switch.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 06-19-2013, 02:48 PM
brads911sc's Avatar
Keuhl, what switch do you use in your kits?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 06-19-2013, 02:51 PM
brads911sc's Avatar
How plug and play are these? I have a binary but want to switch to a trinary to manage my ZIMS fan.
Old 06-19-2013, 02:52 PM
wwest's Avatar
Addresses integration:
Binary Switch w/ R-134a Discharge Port 7/16" - A/C Pressure Switch
Discard the binary pressure switch. Integrating adapter goes right on the side of the compressor and clutch wire is close by. Just splice the pressure switch' compressor control in series with the clutch wire.
Old 06-19-2013, 02:56 PM
Bob Kontak's Avatar
Yes, need some beef.
It has got to be as onerous as installing a 6AL under the driver's seat.
1981 911SC Targa
wwest's Avatar
Directly, same male connection, 4 wires out vs 2.
Old 06-19-2013, 02:57 PM
Bob Kontak's Avatar
Then the fans are controlled via a hot all the time feed from the trinary?
Edit - Oops - timing overlap.
1981 911SC Targa
Old 06-19-2013, 03:02 PM
wwest's Avatar
Well, you can...
Inline Switch Port - A/C Pressure Switch
Or...
Or just replace your binary switch with the trinary one..
Old 06-19-2013, 03:04 PM
wwest's Avatar
Since Porsche uses a 20 minute time delay so the fan(s) will not run after that time period you might want to consider using a TDR, Time Delay Relay. The only downside to not having a limit on run time would be a dead battery, but only in case the trinary switch fan control section fails "closed".
Old 06-19-2013, 03:10 PM
brads911sc's Avatar
But my Zims has its own power source and relay and I only have one wire coming to the compressor. Its basically a low voltage trigger wire. So unlike a traditional SPAL fan I would need three wires and not four. Right now i have this wired into the Binary but not sure that is optimal as it takes voltage from the clutch.
Old 06-19-2013, 03:24 PM
