Correct Trinary Pressure Sensor/Switch
Red Dot P/N 71R7500, GM 35899
Open below 2.81 kg/39.9020 Open above 22.8 kg/323.7600 Fan on 8.4 kg/119.2800 |
Fleabit peanut monkey
1981 911SC Targa |
One does have to do some crafting to get that integrated?
Physical entry into the high side and clearly some wiring time to keep fan(s) on post shutdown and kill compressor if outside operation limits. Former is my concern. Latter just takes time to configure - my take/comfort level.
1981 911SC Targa Last edited by Bob Kontak; 06-19-2013 at 02:16 PM.. |
Main thing I like is that high side over 325 means something ain't right.
2 times 120F = 240 + 50 = 290 psi. Rule of thumb, right? That gives an extra 35 psi before shutdown if idling in the sun on a hot day in Phonix. Set aside theories and arguments. This makes sense. If your system is working fine, not needed. If not, then this protects your system/investment.
1981 911SC Targa Last edited by Bob Kontak; 06-19-2013 at 03:04 PM.. |
French Import
Good info and great timing for me as I need to get new hoses made.
I guess I need to add a "T" connector for the trinary switch.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Keuhl, what switch do you use in your kits?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
How plug and play are these? I have a binary but want to switch to a trinary to manage my ZIMS fan.
Binary Switch w/ R-134a Discharge Port 7/16" - A/C Pressure Switch Discard the binary pressure switch. Integrating adapter goes right on the side of the compressor and clutch wire is close by. Just splice the pressure switch' compressor control in series with the clutch wire. |
Yes, need some beef.
It has got to be as onerous as installing a 6AL under the driver's seat.
1981 911SC Targa |
Then the fans are controlled via a hot all the time feed from the trinary?
Edit - Oops - timing overlap.
1981 911SC Targa |
Inline Switch Port - A/C Pressure Switch Or... Binary Switch w/ R-134a Discharge Port 7/16" - A/C Pressure Switch Or just replace your binary switch with the trinary one.. |
Since Porsche uses a 20 minute time delay so the fan(s) will not run after that time period you might want to consider using a TDR, Time Delay Relay. The only downside to not having a limit on run time would be a dead battery, but only in case the trinary switch fan control section fails "closed".
But my Zims has its own power source and relay and I only have one wire coming to the compressor. Its basically a low voltage trigger wire. So unlike a traditional SPAL fan I would need three wires and not four. Right now i have this wired into the Binary but not sure that is optimal as it takes voltage from the clutch.
