millarg's Avatar
Fast Flashing
Have just posted a separate comment on electrics, as a separate and pre-existing issue, I have fast flashing direction signals.
All directional lights, brake and reverse lights are operational, I am missing one side maker (forwarded drivers - corroded fitting) and do not have license plate lights (removed the rear bumpers - heavy!!!) would the missing bulbs explain the fast flashing?
TIA
Glen 78SC(D) EFI Targa
Old 06-10-2013, 10:12 AM
Senior Member
Jdub's Avatar
Yes, for the flasher bulb only, not the license plate lights. I believe the flasher blinks double-speed to let you know there is an issue.
'78 Targa in Minerva Blue
Old 06-10-2013, 10:20 AM
Send a message via Skype™ to Porboynz
I found that Narva brand bulbs caused issues of fast flash and both warning lights flashing after the initial correct flash. Changed to a full set of the same rated Hella bulbs and everything is good again. A missing bulb will usually only cause that side to flash faster.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 06-10-2013, 11:29 PM
millarg's Avatar
Many thanks, I know I have mis-matched bulbs, will change all out and see if it helps, it is the driver side side marker that is missing due to corroded fitting, but all lights flash fast.
Thanks again.
Old 06-11-2013, 11:31 AM
pete3799's Avatar
Had the same rapid flashing problem......in my case it turned out to be the flasher relay.
Pete
79 911SC RoW
Old 06-11-2013, 12:17 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Get an electronic flasher unit...they do not depend on the resistance of all the bulbs to set the timing.
Bob
Bob Hutson
Old 06-11-2013, 05:35 PM
