78sc's Avatar
Backfire, then no start
Hi all,
It's been a while since I've been driving my 911 or been around these forums. Thought I'd ask you all a question as I get back into enjoying these 911's we like so much.
So, I got mine running again and had been driving it for about a week. One morning last week, I went to start it and it backfired pretty good and then would not start. If I let it sit for a couple of minutes, and tried again it would try to start but then just crank. All these attemps to start were with my foot off the gas pedal. So I took my non-fun car to work and when I got home again, all it does is crank and not even a hint of wanting to fire.
My question is, where do you guys think I should start the troubleshooting? The airbox has a pop-off valve installed. I can't see any cracks in the airbox, but I'm sure there is a lot I can't see with just the airfilter cover removed.
Thanks.
Phil
1978 911 SC
Old 06-10-2013, 11:08 AM
ROW '78 911 Targa
timmy2's Avatar
Is the pop off valve seated on its o-ring properly?
Basic tune up of ignition and check fuel pressures would be next, spark plugs fouled?
Old 06-10-2013, 11:24 AM
jtfreels's Avatar
Check to make sure that you are getting spark. If so then .... check for vacuum leaks etc.
I had a similar occurrence, and after the backfile got no spark, turned out the "coil" inside the distributor had failed. That is "green" wire related.
Just a thought.
Jay
2002 Boxster Speed Yellow
Old 06-10-2013, 11:25 AM
Checked out
McLovin's Avatar
Something has cracked/broken off, and now you have a big vacuum leak that is preventing the car from starting.
Old 06-10-2013, 11:27 AM
kodioneill's Avatar
Pop off valve or broken air box.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-10-2013, 12:03 PM
Banned but not out, yet..
RSBob's Avatar
If you pop off valve popped completely off like mine did remove the air filter and you will see it unsecured. Clean out old glue or adhesive and mix a 2 part epoxy and reseat the valve and you should be good to go
Old 06-10-2013, 12:07 PM
78sc's Avatar
Thanks for the thoughts guys. I will go hunting for the culprit tonight.
Old 06-10-2013, 12:43 PM
78sc's Avatar
So, I checked spark, that was good. Plugs were not fouled. Couldn't find any hoses that got blown off or any cracks that might cause a vacuum leak. Then realized I couldn't hear the fuel pump. Turned out the fuse was blown. Weird! Replaced that and it started right up.
Old 06-11-2013, 09:16 AM
ROW '78 911 Targa
timmy2's Avatar
Good find, and thanks for updating with your results.
Now go drive it like you stole it!
Old 06-11-2013, 09:34 AM
arry911
I had similar problem the other day turned out the fuse was corroded not even blown, Just put in new fuse and it started.
Old 06-12-2013, 08:30 AM
Bandwidth AbUser
Jim Richards's Avatar
Coil failure.
Jim R.
Old 06-12-2013, 08:53 AM
78sc's Avatar
Originally Posted by Jim Richards View Post
Coil failure.
Hi Jim...sorry, not quite sure what you mean.
Phil
1978 911 SC
Old 06-12-2013, 09:46 AM
