3.2 install- DME cable routing
Hello I am getting close to the end of my 3.2 into a '76 project. For the DME cable, I drilled a hole in the back of the rear seat footwell on the driver side. The cable comes through in the middle of the footwell right at floor level The dme is under the driver seat, and there is a bit of extra cable. . How do you merge the obvious presence of the cable into the interior- if you just put the carpet over it-it will look tacky. What have other conversions done? Thanks in advance!
non-whiner
When I removed the dme from my 84 to upgrade to a 3.6, the hole is to the left of the foot well making it easy to route along the base of the driver side sill.
"Too much is just enough." |
cable routing photos
Here are a couple of shots of the DME and cables. I was thinking that I would fit some 2x6 boards on either side and just put the carpet over that.
Is it too late to re-position the DME from 6 o'clock to the 9 o'clock position?
That might give you a straighter cable run. Or run cable along sill or tunnel, see where it lands and re-pos the dme there.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
I agree with Dan if that is a possibility for you. On my conversion, not only is the motronic up at the 11 oclock position (basically in the upper left corner of your bracket, but it is also rotated so that the plug is on the front edge (toward the nose of the car). The wiring lays perfectly against the floor/sill seam. It looks totally factory.
- A pile of British stuff - A growing pile of German stuff ... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....) |
good idea
Thanks guys- I did rotate the DME to the 9 oclock position, and it is much cleaner! Here are some photos.
porsher
Here's another tip.
Instead of hard mounting the DME to the floor get some rubber isolators to keep vibration out of the electronics.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
awesome - andbetter late thannever
inaminit - sry am just posting a pic of my dme stock mount. Yours indeed looks a lot better. nice job
In my pic, rear is to the left - goofy phone pic get rotated sometimes. and my dme fuel pump relay is lying in space not mounted in the pic for now.
