peppy's Avatar
Alternator rebuilder
I am looking for someone who can rebuild an alternator for a 1988 911, in North Carolina or Virginia.
I have a Bosch re-manufactured one from Advance Auto and would like to have it rebuild.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 06-11-2013, 08:39 AM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
Send it to AutoLectrics in Campbell, CA
Starters , Alternators, generators, repair, replace, build
Many years of great service with this company. They do it right, first time.
Mark Petry
Bainbridge Island, WA
81 SC
Old 06-11-2013, 09:17 AM
47silver's Avatar
Send to stellar generator in Pittsburgh. Call mark 412-563-2100. Tell him Gary sent you
Old 06-11-2013, 10:04 AM
peppy's Avatar
Thanks, I found one local and will let him have a look at it.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 06-11-2013, 12:44 PM
47silver's Avatar
alt
make sure they use the pressed in diodes as the original as i was told that they handle the heat better than the external ones.
1975 911S Targa
Silver Anniversary Edition
Old 06-11-2013, 12:45 PM
peppy's Avatar
Got it back in and the light is still flickering on at idle. Voltage is 12.5 car off, and 14.3 at idle with the light flickering.
I checked the blue wire going to the gauge and everything looked good.
The light flickering at idle will drive me nuts.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 06-20-2013, 06:01 AM
47silver's Avatar
measuring
where are you measuring the voltage? should be at the battery.
if that is 14.3 at idle, what is it at 2000?
if you are measuring 14.3 at the battery at idle you light should not be flickering.
1975 911S Targa
Old 06-20-2013, 07:59 PM
peppy's Avatar
I'm measuring at the battery, and yes the 14.3v is at idle.
I went to Advance Auto and let them check the battery and the charging system with their fancy machine. Light is still flickering at idle.
This was after a 20 minute drive
Battery results
voltage 12.85v
Measured 1043 CCA
Rated 800 CCA
Charging system test
no load 14.01v
loaded 13.68v
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 06-21-2013, 01:46 PM
bavaria911's Avatar
Glen Burnie Generator and Carburetor Shop in Maryland. They just rebuilt my Marchel 55 amp for $70. Looked like new. They have 35 years of service. tele 410 761 0056.
Turn around time was 2 days.
Scott
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 06-21-2013, 05:57 PM
