GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
71 starting concern ?
I was driving my 71 yesterday, which is always a great experience, and noticed my radio would flicker on and off quickly. I figured it's a loose ground connection and would check it when I made it home. However I stopped somewhere and when I went to start the car it wouldnt turn over. I checked the positive battery connection and found it secure but the wires were warm. I attached jumper cables and the car turned over fine and started right up. I drove the car home. Turned it off and then was able to restart it several times without a concern.
Any ideas.. or just a weak battery? (battery is actually not that old) (alt. also not old)
Thought id post to get some ideas before I go to look it over, even if it is just something simple. Thanks
Old 06-13-2013, 10:58 AM
it is only warm whenever there is a bad connection. It will burn out your alternator and boil your battery.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-13-2013, 11:16 AM
GotaT's Avatar
I did notice the main positive lead connected to the battery firmly. There were 2 other wires attatched to the top of the positive post that were in fact a little loose secured each with a 10mm bolt. the 10mm is what was loose on each. I believe one of them goes to my ignition switch. Think this could be the culprit?
Old 06-13-2013, 01:31 PM
Send a message via Skype™ to Porboynz
Take it all apart and clean and retighten, simple insurance. New fasteners make it look much better.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 06-14-2013, 01:00 AM
