LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average.
Banned
a/c vacuum pump recommendation
I'm going to buy an a/c vacuum pump to use on my 930 as well as on my other personal vehicles. I was wondering what CFM rating is considered "good". I did a search but couldn't find anything . . .
Old 06-14-2013, 07:02 PM
Gordo2's Avatar
Harbor Freight Vacuum
Ronnie,
COLB might chime in - he bought the Harbor Freight vacuum unit for the R134 conversion we did on his car recently.
First Project thread: 88 Cab A/C retrofit on the Cheap
The little pump seemed to do a sufficient job evac'ing the system. We ran it for about 15min initially to see if the system had any gross leaks, then a full hour for complete evac prior to charging with R134.
Considering the (hopefully) limited frequency that a non-pro would be using a vacuum, it's hard to beat the price.
Spec's may be on HF website.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 06-14-2013, 07:42 PM
I have a small 1.5CFM pump. I believe it's this one:
https://www.ackits.com/pc/90060/Vacuumpump/90060+-+Mastercool+1.5+CFM+Dual+Stage+Vacuum+Pump
I've used it on probably 10 cars, it works OK, with time and repetition it will pull down about 21 inches of vacuum - no more. In hot weather (85+ degrees) I have to run a box fan or something on it while it is running or it will overheat after 5-10 minutes and shut down. In cooler weather (50-60 degrees) it does great. But who works on A/C when it's cool out?!
Anyway, good enough for occasional use and I believe it is higher quality/more effective than the air-compressor driven units. But not pro quality.
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes.
1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights.
Old 06-14-2013, 08:02 PM
Banned
You don't need a vacuum pump. Just use two SPAL fans and trinary switch. Your AC will be fine.
Old 06-14-2013, 08:11 PM
BTW, the one I linked, I think you can find for about $100 now. I think I paid just a bit more than that a few years ago, not sure why the high price on ACKits.com.
Old 06-14-2013, 08:48 PM
Banned
Ha! Now it is time for YOU to get the ceeeegarrrrr!
Old 06-14-2013, 08:52 PM
Banned
Thanks for the suggestions.
wwest's Avatar
Originally Posted by Gordo2 View Post
Ronnie,
Gordo
HF is currently handing out 25% discount coupons for use ONLY on the 4th.
http://www.harborfreight.com/25-cfm-vacuum-pump-98076.html
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=2&ved=0CDEQFjAB&url=http%3A%2F%2Fwww.harborfreight.com%2Fmanuals%2 F98000-98999%2F98076.pdf&ei=_um7Uf_MMcWtqwGHq4GADg&usg=AFQjCNH2MGr0IZh7ojTtsZVnqA8YQltdJg
Old 06-14-2013, 08:57 PM
Best friend is my dog
You can buy a 2.5 cfm unit from Harbor freight Tools for a little over 100 bucks.
Old 06-14-2013, 09:00 PM
Synchro Joe's Avatar
Vacuum
Now that is funny chit!
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 06-15-2013, 09:31 AM
1988 Carrera
shadowjack1's Avatar
Your local FLAPS may let you use one for free. You put down a deposit, use it and then return it for a full refund.
Old 06-15-2013, 10:24 AM
I have the 6 cfm Robinaire pump, but you can get a smaller 4 cfm unit as well.
Be sure to change the pump oil each time (Grainger carries it). I would not buy HF on this item.
Old 06-15-2013, 11:30 AM
69-912-swt's Avatar
+1
Bill Kent
https://www.facebook.com/#!/NoSweatPhotography
1987 Carrera Targa
1969 912 SWT #0053
Old 06-15-2013, 01:06 PM
