Czar of C.R.A.P.
dfink's Avatar
turn signal primary wires
OK trying to put the original turn signal and light switch back in the race car. I have been studying the wire diagram for days. I finally have the High/Low beams working and the left right tail/park lights. I can't however figure out how to get the turn signals to work. I don't seem to be getting any power to any of that system. I have in the car the original light switch, turn signal switch, emergency flasher switch, and brake light switches. I have several wires hanging that I just can't tell where they go.
I have a group of seven wires, white, yellow, black/green, red/black, black/white, green/red, brown/white
Those are in the trunk and I know at least some of them went to the fuse panel because of the terminations. I don't have the original fuse panel any longer.
I have the left and right wires going to the turn indicators, I have the left and right wires I was using with the aftermarket unit going to the front and rear.
It seems like I am missing some sort of controller that would tie the brakes, flashers and signals togeather but can't find it on the schematics or in my pile of wires.
I guess I need to know how it gets power.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 06-15-2013, 04:04 PM
Czar of C.R.A.P.
dfink's Avatar
Sorry car is 1984 911 cabriolet
66 912 Coupe
Old 06-15-2013, 04:20 PM
winter
Winter's Avatar
On my '75 the turn indicators are also linked to the emergency flasher switch. I dont know offhand the colors of the wires that link to the e-flasher, but I do know that if they are not connected, everything works as you have described, sans flashing turn indicators. Hope this helps.
Old 06-15-2013, 06:58 PM
Czar of C.R.A.P.
dfink's Avatar
Figured it out.
66 912 Coupe
Old 06-16-2013, 05:34 PM
