Troubleshooting ignition problems, but it's all Greek to me.
Hey all,
Last Summer I bought my ROW market 1977 911. At one point in its life someone swapped in a later model 3.0L SC motor, and along with that, a Permatune ingition system. More info on the car can be seen here: http://forums.pelicanparts.com/porsche-911-technical-forum/685638-new-porsche-owner-1977-911-coupe.html Since buying the car, I have done new oil/filter, Magnacore wires/plugs, distributor cap and rotor. The last time I actually drove the car any distance was on a Sunday/funday with my girl friend and we experienced some issues with intermittent power loss/surging, backfiring, and intermittent inability to start. This was maybe toward the end of last Summer. I have since started the car every few weeks to move fluids and driven around my parents' neighborhood and I don't believe any of the above issues persisted. The only thing I've done to the car since it went into hibernation was a heater backdate with the parts supplied here at Pelican. Today I finally got the car off of jackstands and out of my parents' garage after refinishing the wheels with my own new powder coating system (highly recommended). I was so excited to get the car back on the road and drive, but alas, she will not start. At all. We did the basic tests including checking fuel, air, etc... The conclusion after my basic mechanical checklist yielded that I have zero spark. I've done a good bit of researching tonight on ignition issues and seemed to find stories consistent with my own. Unfortunately, most of my limited knowledge is strictly mechanical, and I hate to say it, but I need someone to 'hold my hand' on this problem with electrical gremlins. We tried to find a generic coil from local parts stores to throw into the car, but everyone told me they were all vehicle specific and had nothing for the car. I can't see this being entirely accurate. My main question is- what's the easiest way to test my ignition system without delving into the mess of wiring that is the harness and opening a bigger can of worms? Also, if anyone manages to read my original thread, you'll know that I'm relatively limited on funding for simple issues. I'm hoping this can all be solved for *<$500. Thanks so much for any help. I can supply any pictures needed when I return to my parents' house tomorrow to work on other projects. -G.A. |
GA,
If you put your location in your profile you might find someone nice enough to come by and lend a hand. First thought is if it's been sitting that long is the battery dead or bad? I keep mine on a battery minder as much as possible when I know it won't be driven to prevent sulfation. Do you have a digital multimeter? What happens when you try to start the car? |
I am in Virginia Beach, VA. I'll update my profile with the information. The battery I had in the car was a brand new one (5 days old) from my Lexus. No issues there. My dad does have a digital multi-meter. When starting the car, the engine will crank but never fire. The belt and fan spin appropriately but nothing catches. I read some more information last night about cars mysteriously starting after sitting for however long. I'll give it another shot today to see if I get lucky. |
You can use a timing light to see if your coil is firing. Clip it to the plug wires and see if your light triggers while cranking. If not, work your way back from the CDI to see if the coil is getting a trigger signal and then that the CDI is getting a trigger signal from the variable reluctor wheel in the distributor. The distributor signal might require an oscilloscope to detect but you can see a voltage change on the low voltage setting. Where are you located?
Intermittent spark and no spark are sometimes issues with the Permatune CDI. I have had two fail. You can swap an MSD or Crane system pretty easily. |
I've read on here that installing an MSD is a breeze, and I've also read that it's a pain. I do love jumping into projects myself, but I'm reluctant to try to the MSD simply because I have no real knowledge of anything electrical. |
I just found a great deal on a new MSD 6425 ingition system and blaster coil. I think I'm going to buying these tonight and hopefully avoid having to worry about the PermaTune. If anyone local to the Virginia Beach area happens to read this and is experienced with this kind of install, I'd be more than happy to supply pizza, beer, and gas money for your time!SmileWavy
GA,
Whoa! Hold on there! You could be right, but you could be wrong. If you're on a tight budget, swapping parts is an expensive way to troubleshoot. If you have a multimeter, then there are methods on here for testing the coil with the multimeter. Try testing with a timing light as suggested. Do you hear the CDI box whine when you try to start the car? The reason you read that MSD can be difficult is that you MAY need the tach adapter too and it is not a completely drop-in replacement for the Bosch or Permatune CDI. |
By the way, I'm not saying it's not the CDI -- definitely could be -- I'm just saying you can verify it is the problem before you spend the money and find out it is something else.
Whoa Hoss. Before you spend money, spend some time getting to the cause of the problem.
This thread may be helpful: http://forums.pelicanparts.com/porsche-911-technical-forum/528944-ignition-problem-troubleshooting-electrical.html Also, from another thread (http://forums.pelicanparts.com/porsche-911-technical-forum/449527-how-do-i-check-coil-timing-light.html): Quote:
Tirwin and Harry-
Thank you both for the helpful info. I assure you, I'm not one to jump the gun and spring on parts. Honestly, I'm planning for the 'worst' and hopefully minimizing the time waiting for delivery. Ditching the PermaTune has been on my short list since I got the car as part of my baseline maintenance/mods. To answer your questions- there was no sound coming from the PermaTune CDI with the key on. I had not thought to check the coil with the 'telegraph' test, but it seems very easy. It's funny you should mention the tach-adaptor. I actually lost functionality in my tach a few months ago and have yet to hunt down the reason. Would this be a symptom of a failing CDI as well? Something I can definitely try is throwing in a cheap, generic coil and seeing if it does anything. Thing is, every parts store around town tells me they're vehicle specific and I have no clue what other vehicles would have compatible coils- at least, parts that would be kept on hand in-stock. Harry- I will try your steps later in the week- possibly tomorrow evening. #1 and #4 are definitely "No's". |
MSD blaster II coil is good for stock coil replacement.
The Blaster II is the part currently sitting in my Amazon cart. The coil, ignition set up, and super gaudy MSD coil bracket are available together for only $270 shipped. It's a much better deal than I've seen elsewhere. |
FWIW, Permatunes do not make the whining sound. Frankly, I would try to get a stock CDI. The issue with an MSD is installing it (typically does not fit in space of original CDI and there are wiring issues you need to get right) and getting it to work with the Porsche Tachometer. Also, MSD units tend to destroy the rev limiting rotors that are installed in factory CDI Equipped cars. You will need to get a non-rev limiting one and be sure the MSD unit includes a rev limiter feature. Do some reading to get an idea of what you need to do to install your MSD. There are many threads on the subject and it will give you some ideas of where to install the unit and what issues you will need to resolve. |
easy 3 step process 1, remove the permatune system 2, install the bosch CDI and coil 3, enjoy. a overly simple solution i know but the best bang for longevity and performance. You can get rebuilt units from our host and new coils. costly but there plug and play.
Harry- The 'High Vibration' model (8222) is also sitting in the cart while I do some more research. Maybe I am missing something when it comes to mounting an MSD- I have seen them mounted in the same spot as my PermaTune, an haved seen others go so far as to mount them under the carpeting in the cabin. I will dig some more on the installation for more clarification. From what I've read on the OEM CDI units, they are not cost effective when compared to the MSD. Am I understanding this correctly? As for the rev-limiter, I wonder if your wording is a little off. When you say get a 'non-rev limiting one', are you referring to an MSD system? I was a little confused when you followed that up with finding an MSD that did include a rev-limiter. FWIW, the part sitting in my online cart is a model 6AL-6425 with adjustable rev-limiter. I have seen the need for the tachometer adapter. I considered contacting MSD directly to find whether or not I'd need the adapter, but since my car is a Frankenstein already, they may have no real basis to go on. Thanks again for all of the information. I've been reading threads most of the day trying to catch up on the learning curve with this topic. |
Harry-
This is another opportunity for me to sound ignorant, but how do I know if the rotor is a non-rev-limiting one? The rotor in the car now is brand new ( maybe 100 miles) purchased here at Pelican for my motor. http://www.pelicanparts.com/catalog/images/Connect-Thumbnails/93060290200-M14.jpg Thanks again for your input. Too bad you're 3,000 miles away or else I'd have to buy you a beer! |
that is not a rev limiting rotor but it is a resistance one, you need to get a non resistance one from a VW for the MSD unit (it never ends) looks like the one on the left
http://forums.pelicanparts.com/uploa...1371435774.jpg sorry Harry |
James- Thanks for the clarification. Will this rotor work with the current distributor cap that is currently on with the resistance rotor? Also, would you happen to be able to provide a link for a correct part?
yes, here is the way you want to go, many have installed MSD boxes and some have failed or only lasted a few months/years. you have to follow the instructions to the letter, if it says find a good solid power source, i would use the large gage wire direct to the battery using the best connector i could find. ground wires to known good body ground, no chance of loosing any of these contacts, shielding and supporting them. using new wires, cap, non resistance rotor, new plugs, mounting the unit on shock mounts. in other words, make the installation as "hardened" as you can, no skimping on anything. this is the heart of the engine. download the instructions from MSD (pdf file) and review it
The Magnacor wires and Bosch plugs in the car are brand new. I shouldn't have to replace them along with the MSD, should I? They may have 50-100 miles on them. The cap is new as well.
yep your good to go there
crap, yeah ill look, i think it from a msd install thread on here
Buy the Napa EP407. $3.99 each....Works just fine...
look at this thread "rotor for MSD ignition" |
Nothing to be sorry for. I was going to post the same pictures when I found them. |
Thanks for stepping up. I know there is a lot to getting this right. Part of the reason, when I was in the same place (failed Permantune), I punted and got a Bosch CDI box. |
i still think the bosch unit is the gold standard in CDI's but time has tarnished them and replacements are expensive.
Harry and James- Thank you both so much. I placed my order tonight for the MSD system and coil. I will check locally for the rotor while I wait for the items to arrive.
I just considered something that completely slipped my mind the other day. After getting the wheels put back on the car and carefully using the correct jack points to bring her back to ground, I noticed she was sitting VERY high off the ground. At first I chocked it up to the suspension drooping for the better part of 2 months, but it was simply too much to be that. I checked under the car to find that someone in the house decided it would be a good idea to hide my $800 Arai motorcycle helmet under the car, just about dead center. The full weight of the car was literally resting on top of the helmet. After a few minutes of panic and racing to get her back in the air, I removed the helmet and set her back down. All was much better. To make things more interesting, there was not a single bit of damage to the helmet (PHEW!)
Question here- is there anything running dead center of the car such as hard fuel lines that could have possibly been crushed by the helmet? I did get fuel flow going into the cylinders while cranking, but it was not a large amount by any means. I'm not wise as to how much should be coming out at those connections while cranking the key. Any thoughts? |
nothing there, the arms are important but that is about it
All-
I swung by the car this morning before going to play babysitter to a buddy who ended up in a bike accident last night. I noticed that my car doesn't have the original black 6-pin connector everyone's using with their MSD installs. It's got 2 white connectors hooked to eachother. I imagine this is what the PermaTune would have been installed with? I'll try to get some pictures sent over, but I'll likely scratch my head for a bit tomorrow before starting the install. |
Connector from the PermaTune to the car:
http://img.photobucket.com/albums/v1...A_IMAG0122.jpg http://img.photobucket.com/albums/v1...A_IMAG0123.jpg Wiring mess: http://img.photobucket.com/albums/v1...A_IMAG0124.jpg |
The White 6 pin conector is a suitable replacement for the Black connector on your harness.
It is exactly the same casting and I have seen both black and white on various harnesses from the factory. The tabs on the side are easily removed to make it true to factory form. If you want to send me some pictures of the current harness installation I'd be happy to help you figure out what has been done and what should be fixed if needed. From the close up pictures it looks like a mess. My email address(s) are in the first post here: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/740894-building-sc-mid-year-engine-harnesses.html |
You've got an email. |
"Reverse engineering prohibited" written on side of Permatune unit is straight up funny.
it's really a blessing
Today is the day! Let's hope she fires.
| All times are GMT -8. The time now is 08:22 PM. |
