Swb rear crossmember the bit w/ turrets
Rust claims another piece of bodywork on my 68S.
Can I backdate a lwb crossmember for swb car? Better to replace with section from a dry state donor? Or refabricate the strut turrets? Thanks Rich |
Buy a solid crossbar mount and replace the rubber inserts. I went with Wevo and I am very happy. You send them the crossmember and they for the new mounts in.
Pete I think he means the shock mount.
For a 68S, yes, replace with donor section. For the LWB cars the mounts are different and they change after 1972 as well, the turrets get larger. How is your torsion tube?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Have replaced tube and repaired chasis with longitudinal repair panels.
Old tube was mostly held in with sealer, rust and a square iron section welded to the rear kick panel that connects seat pressings to the floor. Yikes. |
