Swb rear crossmember the bit w/ turrets
Rust claims another piece of bodywork on my 68S.
Can I backdate a lwb crossmember for swb car?
Better to replace with section from a dry state donor?
Or refabricate the strut turrets?
Thanks Rich
Old 06-17-2013, 11:35 AM
PeteM1965's Avatar
Buy a solid crossbar mount and replace the rubber inserts. I went with Wevo and I am very happy. You send them the crossmember and they for the new mounts in.
Old 06-17-2013, 01:32 PM
304065's Avatar
Pete I think he means the shock mount.
For a 68S, yes, replace with donor section. For the LWB cars the mounts are different and they change after 1972 as well, the turrets get larger.
How is your torsion tube?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-17-2013, 02:07 PM
Have replaced tube and repaired chasis with longitudinal repair panels.
Old tube was mostly held in with sealer, rust and a square iron section welded to the rear kick panel that connects seat pressings to the floor. Yikes.
Old 06-17-2013, 03:28 PM
