compression check and head studs?
Can compression and leakdown be used as a diagnostic for broken head studs? I get the feeling from reading archives is the answer is "no", but I figured I'd ask directly. If the engine has good even compression and low leakdown, can one feel OK about the studs, or is pulling the valve covers the only "gold standard"?
Valve covers have to come off. Put a wrench on those nuts! OUCH!
Robert Stoll 83 911 SC 83 944 |
Navin Johnson
yes, and no.. you can have bad compression readings and leak down readings with perfectly good head studs, you can also have great compression readings, and leak down readings, only to break a head stud the next time you start the engine..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Its a good investment, and not doing this check is really not worth the risk. You deserve a good car, and we really want to see you happy.... no, really!
Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site |
I would second Robert's advice. It is easy to pull the lower valve covers and hit the barrel nuts with a hex wrench just to make sure.
You don't want to do that 3.6 conversion any sooner than is needed!!
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Author of "101 Projects"
I would pull the valve covers off to check for broken ones, but I would not recommend putting a wrench on them. Rust can get in there and create a nasty situation.
What if one breaks? Can the owner of the car sue you for rebuild costs? Possibly... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Please....
THAT IS NOT TRUE FOR A 3.0 L CAR... If the studs are broken ( not loose) the head studs will basically fall off. You guys, are just too paranoid about this process. If a head stud IS broken, when the head cover is off, the stud (bolt) will basically come out wih a socket..simple as that...... There is NO hisssing when a "cold start" is tested ( this would only be the case from a earlier car)..... You guys are giving Todd, ALL this junk mail about "whAT IF'S".I'm sure Todd's wrench will the "knowledgable" "NOSTATIC" good info...
jeez..let the guy do his thing.....believe me Todd is very good, and he DEFINITELY knows his sh** !!! |
Team California
I say pull the lower VCs, how much are a couple of gaskets? If one is broken, it will be laying there in the galley. BTW, my car has like-new compression in all cylinders, including the one w/ the broken stud. Sure wish I'd done the VC thing, not just compression check. As far as will one break in future, who knows? If overall engine health is excellent, (like mine), you can always JUST replace lower studs, which is what I will do. Good luck, keep us posted!
Denis |
Senior Member
Broken Dilivar head studs on older 3.0 and 3.2 motors are a given.
Bet the farm on it. When it happens, fix the motor and continue to drive. NS: If you are a chronic worry-wart, you shouldn't own a 20 year- old Porsche. Wayne says: "What if one breaks? Can the owner of the car sue you for rebuild costs? Possibly... " Only in America.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
