Senior Member
Jdub's Avatar
Ever have your front tire get caught in the unrolled lip of the fender?
A sort of pop/bang on the front, cannot figure out what happened, then noticed on examination that the inner lip of the rightside front wheel well was slightly pulled down, into a pointy triangle facing straight down. Running 7" with a 205 (NOT 225), so what the heck?
The car sits at ~ 25and1/4" on that lip, as measured from ground through center exact of wheel. Ever hear of this? Was pretty surprised...
'78 Targa in Minerva Blue
Old 12-16-2013, 11:42 AM
Porchcar guy's Avatar
What is your shock condition. Static ride ht. is different than moving as it depends on the road surface, potholes etc...I had the same on my SC front drivers side. Lip cut into my then 225 so I put 205's on and it pulled the 11 oclock position down. then I rolled the lip.
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 12-16-2013, 11:47 AM
I'd like to know, also. I bought my Carrera with that similar triangular "dent". Mine is on the driver's side.
- Steve
'70 Tangerine 911T
'86 Guards Red 911
'57 Black MGA
Old 12-16-2013, 11:48 AM
Hows your camber? If it has slipped and you have too much positive camber I could see the tire hitting the fender lip. This happened to me with 225's on 7's in the front, now that I have more neg. camber it's not a problem.
Chris
'75 911s 3.2 - Ice Green Metallic
‘87 951, '05 987 S
'21 Jeep Gladiator
‘18 Tesla ModelX 100D, ‘20 Model 3
Old 12-16-2013, 11:59 AM
boss11's Avatar
i have 215/45 on 7" rim on the front of my SC, -1 degree camber, drivers side catches the lip under hard braking and hitting bumps at speed, im looking at rolling the lip
82 SC Targa Guards Red = Toy
04 E55 AMG Brilliant Silver = DD
04 Cayenne Turbo Platinum Grey on 22s = Previous DD
80 Wide body 12AT RX7 Black 350+ hp= Previous Toy
78 Alfa Romeo GTV Blue = My 1st Cool Car
Old 12-16-2013, 12:04 PM
Senior Member
Jdub's Avatar
That's the thing gents - completely new suspension so nothing worn, we set the ride height, then I took it over to a trusted place for alignment. No major potholes or anything that might make me think something shifted or otherwise.
I mean, unless the cap on the T-bar can just adjust itself? If a T-bar can jump its teeth? Cannot imagine that - everything looks tight and right after lifting car and inspecting visually.
So I am thinking this is another quirk of our cars? Thanks very much for your thoughts on this.
EDIT: I am running very little camber - had the shop set this up for Country Mouse in the Big City road work - no DE, etc.
EDIT2: Funny thing is that it is always the LEFT side that causes concern - that seems to always be the one that rubs on full wheel lock, turning.
Old 12-16-2013, 12:15 PM
I have had similar issues, only on the left side. Solved it by changing to narrower 205s (Bridgestone S-02 is has about 0.4 inch narrower section width than most other 205s) AND bending the fender out. When troubleshooting I found the left fender wheel arch to be about 1/2 inch narrower on the left side. I used a piece of hardwood to pry it out gently and now both sides are equal. Problem gone
Camber is the same btw on both sides
80SC (ex California)
Old 12-16-2013, 12:27 PM
Exact same thing with my car! Same measurement too which is quite a coincidence.
Jdub - so this just started after the alignment?
Chris
‘87 951, '05 987 S
'21 Jeep Gladiator
Old 12-16-2013, 01:05 PM
86FlatSix
JQ911's Avatar
driver side fender
This is how mine looks like at the driver's side. Mine sits 24.5" upfront running on 225/45/17s. I have not rolled it but an alignment and camber made a big improvement except for hard fast corners. Will roll fenders soon and might mount 215/45s on my next cycle.
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 12-16-2013, 01:49 PM
Bill Verburg's Avatar
It happens all the time even 7x16 ET23.3 w/ 205/55 x16 tires is an aggressive fit
I much prefer shaving the lips as opposed to rolling them, you get a lot more room
Bill Verburg
Old 12-16-2013, 01:53 PM
86FlatSix
JQ911's Avatar
Hi Bill,
Can I just cut or grind the affected portion only maybe 1 1/2 inch of the lip of the above photo?
Old 12-16-2013, 01:57 PM
Originally Posted by JQ911 View Post
Hi Bill,
I used a hi speed air powered body shop saw on mine, less heat build up that way
Bill Verburg
Old 12-16-2013, 02:07 PM
86FlatSix
JQ911's Avatar
Got it. Thanks!
Old 12-16-2013, 02:08 PM
Senior Member
Jdub's Avatar
Chris: No, not just after alignment. It has been a bit of time, but it has only just happened to me.
Old 12-16-2013, 02:29 PM
I too suggest grinding away offending metal. However, there's only a couple of sections that need that remedy. Apply a protective coating on any bare metal, and leave enough lip to provide sufficient rigidity and an unmolested appearance.
Sherwood
Old 12-16-2013, 04:30 PM
