Recharging AC, how do I keep air out when switching cans?
I evacuated, drew a vacuum and am in the process of recharging my 134 AC system in my 930. I have the manifold gauges connected to the high and low ports (with the valves closed). How do I attach a can of freon (or replace a can of freon) to the yellow charge hose without introducing air into it? This air will go into the system when I open the low port gauge valve. There is no valve at the end of the charge hose to close before attaching or switching cans. As you can probably tell, this is my first time doing this.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 06-23-2013 at 08:31 PM.. |
hook the freon to the line and before opening the port valve, slightly loosen the supply line end at the manifold and allow line to purge itself. Repeat for next can
Ok, that was the only way I could figure too. One other thing I want to confirm. I was under the assumption that the valve which pierces the can top to let the freon flow will let air in even if I close it all the way down and remove the empty can. Is the purpose only to pierce the can or does it actually stop flow if you close it all the way down and remove the can. If this is the case then I wouldn't need to purge.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
always purge to be sure.
when you first connect the gages, purge the lines that are connected to the system. i usually jsut crack a valve before connecting a can
I charge using the kit that comes with a low side pressure guage. Simple remove the quick connect to attach a new can.
Flat Six
^^ sage advice; +1
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
