jwakil's Avatar
Recharging AC, how do I keep air out when switching cans?
I evacuated, drew a vacuum and am in the process of recharging my 134 AC system in my 930. I have the manifold gauges connected to the high and low ports (with the valves closed). How do I attach a can of freon (or replace a can of freon) to the yellow charge hose without introducing air into it? This air will go into the system when I open the low port gauge valve. There is no valve at the end of the charge hose to close before attaching or switching cans. As you can probably tell, this is my first time doing this.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 06-23-2013, 08:27 PM
964TargaC2's Avatar
hook the freon to the line and before opening the port valve, slightly loosen the supply line end at the manifold and allow line to purge itself. Repeat for next can
Old 06-23-2013, 09:08 PM
jwakil's Avatar
Ok, that was the only way I could figure too. One other thing I want to confirm. I was under the assumption that the valve which pierces the can top to let the freon flow will let air in even if I close it all the way down and remove the empty can. Is the purpose only to pierce the can or does it actually stop flow if you close it all the way down and remove the can. If this is the case then I wouldn't need to purge.
Old 06-23-2013, 09:36 PM
T77911S's Avatar
always purge to be sure.
when you first connect the gages, purge the lines that are connected to the system. i usually jsut crack a valve before connecting a can
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-24-2013, 04:59 AM
wwest's Avatar
I charge using the kit that comes with a low side pressure guage. Simple remove the quick connect to attach a new can.
Old 06-24-2013, 08:21 AM
Flat Six
Flat Six's Avatar
^^ sage advice; +1
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 06-24-2013, 03:59 PM
