GothingNC's Avatar
Ducktail fit problems
Just got the following photos from the body shop.
Too much gap on the P/S and if they move it from the D/S it drops the P/S bottom corner too low
I am stopping by the shop afterwards to take a few more photos.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 06-24-2013, 12:31 PM
Speed Dog's Chauffeur
Dodge Man's Avatar
All Fiberglass Duck?
Is it an all fiberglass duck? I got lucky with my all fiberglass duck fit years ago. The $1000 price tag for the converted steel lid is a bit steep unless you want to run 100+ mph with a duck. Did you fit the grill yet? To reach thru the thick fiberglass, I had to make extension bolts for most of my grill attachments. I lathe cut, drilled, & tapped 12.9 axle bolts to attach the grill. I broke a lot of taps. Best of luck.
Old 06-24-2013, 12:39 PM
GothingNC's Avatar
Yes, it is all fiberglass.
John D.
2012 Golf TDI
Old 06-24-2013, 12:40 PM
Senior Member
Jdub's Avatar
Disappointing but not uncommon. Smarter minds than mine will chime in, but you might also cross-post this on the Bodywork BBS.
Wild eyed guess says lead body putty if possible. It is going to look awesome so just this speed bump for now...
'78 Targa in Minerva Blue
Old 06-24-2013, 12:52 PM
Well either the duck is square or the aperture into which it is going is square (probably). Why not measure across the diagonals of the engine bay first to see if that is square?
Just a thought
Ian
Old 06-24-2013, 01:01 PM
GothingNC's Avatar
Ian,
Good question, I will check on the measurements.
Thanks !
John D.
2012 Golf TDI
Old 06-24-2013, 01:11 PM
Dodge Man's Avatar
Weep Holes
I hope that you get the fit sorted out quickly when you visit the shop. I highly recommend adding some(3) weep holes on the engine side of the tag light bosses(on the corner/radius). The inner pocket around the 72-73 tag light area can collect & hold water. I had to add weep holes to my 73's duck to keep the tag lights from swimming in wash/rain water and corroding.
Old 06-24-2013, 01:14 PM
Common issue with GRP panels, simply build the edges to oversize with grp ( not filler) then re profile to fit. I,ve done several of these no sweat.
Andy
Old 06-24-2013, 01:17 PM
GothingNC's Avatar
Good news. After some more alignment tweaking we were able to get the gaps aligned much better.
John D.
2012 Golf TDI
Old 06-24-2013, 03:26 PM
GothingNC's Avatar
Progress photo
John D.
2012 Golf TDI
Old 06-24-2013, 03:27 PM
Unobtanium-inc's Avatar
Fitting ducktails sucks. Ask me how far a ducktail will fly when hurled like a frisbee across the shop...
Good to see yours is looking better! -- Matt
http://www.unobtanium-inc.com
356 Registry 17369
Early 911S Registry
912 Registry, PCA
Old 06-25-2013, 08:20 AM
nineball's Avatar
it's a bit hard to tell in your pics but if your duck has the provisions for the earlier style license plate lights you will need to remove the rubber strip at the bottom of the opening for the duck to close properly.
here is the area i spoke of
rubber strip to remove (i replaced it with some foam weatherstripping)
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 06-25-2013, 11:05 AM
GothingNC's Avatar
It's On
John D.
2012 Golf TDI
Old 07-05-2013, 11:08 AM
Andy
I did this to mine as well to make it fit. GRP is easy to work.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 07-05-2013, 08:43 PM
GRP = ?
thanks
Old 07-06-2013, 02:04 AM
86FlatSix
JQ911's Avatar
Originally Posted by 911pcars View Post
GRP = ?
thanks
Glass Reinforced Plastic or Fiberglass
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 07-06-2013, 08:25 AM
