TedSlick's Avatar
Know where I can get a 911 CAD (AutoCad) drawing file?
Seems lots of you guys are involved in engineering, so I thought maybe someone here could help me out with this.
I need plan and elevation views of a 911 (80's model preferably) in AutoCad (.DWG) or Microstation (.DGN) format. WindowsMetafile (.WMF) might also work.
Thanks...will be very useful in some garage and site planning I'm doing.
Old 07-27-2002, 09:07 AM
andyu911's Avatar
I have 993 front, rear and plan view. Proportion is close not perfect. Interested?
Andy
'87 Carrera
Old 07-27-2002, 09:47 AM
TedSlick's Avatar
^up
wheeee...this request slipped away fast
Andy, yes I'd like to try those files
Anyone have drawings of the 80's style 911?
Old 07-28-2002, 08:32 AM
I've got a 3-D SC.
Old 07-29-2002, 12:18 PM
stray15's Avatar
Send a message via AIM to stray15
I would also love to have those files. I have a 924 drawing. It isn't real good though.
Email is swtncdly@aol.com
Thanks!
Old 07-29-2002, 12:31 PM
Navin Johnson
TimT's Avatar
You can get really good drawings of the 911 from the factory repair manuals. Volume 2 has the body work section for the 911, along with drawings of all the critical dimensions. If you have access to these manuals make some copies. I have Vol 1 which is the engine and drivetrain. Lots of clubs or groups of friends pool money and buy the manuals, but usually only Vol 1, befriend a mechanic that has the full set and ask to make copies of the drawings.
You could then do the wire frames on autocad or microstation, then all you would have to do is put a surface on the wireframe
I was going to make a wireframe dwg of the 911 then run it through some FEA software to run torsion, impact and other load tests on the 911 so I could learn where to remove material to make my car as light as possible, and where to reinforce fo drive safety
'69 911 GT-5
'75 914 GT-3
and others
Old 07-29-2002, 01:01 PM
TedSlick's Avatar
TimT, that was going to be my next move (find dimensioned drawings and draft it myself). Ended up locating a .3DS file and converting to AutoCad.
I can now view/plot/render this 3D model '82 911 from any angle:
Also found the 993 (2D only):
...and this '55:
Lots of stuff available...
Old 07-29-2002, 06:15 PM
tbitz's Avatar
Wow!
Can I get the above files too (911, 993 and 550)?
tbitz@yahoo.com
Thanks,
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 07-29-2002, 06:29 PM
TedSlick's Avatar
YGM
Old 07-29-2002, 06:53 PM
I would be interested in all the 3D files from above..
seres@attbi.com
thanks.
Old 07-29-2002, 07:19 PM
TedSlick's Avatar
sure, Wayne...
Lemme back-grade them (to Acad 13 or so) and I'll send them along. Then you'll be able to access them with older versions.
Hmmm...just realized I don't know where to send you email with attachments. Will try wayne@pelicanparts.com
Old 07-29-2002, 08:08 PM
andyu911's Avatar
That would be great if we can put them together here. I always have the same 993 on most of my drawings. Also like to have more varieties Porsche.
Andy
'87 Carrera
Old 07-29-2002, 09:20 PM
Jack K's Avatar
Ted
I would appreciate the files - I use AutoCad 2000
jkampel@bigpond.net.au
Tx
Jack K
97 993 TT
82 SC Targa [yep, bought it back ]
Previous - 97 993 2S; 89 Carrera; 82 SC Targa; 66 911
Old 07-29-2002, 11:54 PM
TedSlick's Avatar
Jack, look one post up from yours'. Wayne posted a link to the files.
You can really goof around with them:
...and the accuracy is amazing:
Old 07-30-2002, 12:12 AM
Can I get a copy of the 911 CAD drawing please?
john.adams@clariant.com
Thanks!
John Adams
1980 ROW 911SC
Old 07-30-2002, 04:26 AM
tbitz's Avatar
You can download a free dxf/dwg view here:
http://usa.autodesk.com/adsk/index/0,,837403-123112,00.html
This viewer allows you to rotate the images to view them from any angle.
Tony
Old 07-30-2002, 07:50 AM
Please send me the 3d blueprint of porsche 911 at scpatil.345@gmail.com
Thanx...
Old 02-29-2012, 11:43 PM
