Where can i obtain a step by step instruction article on removing the AC blower motor inside the "smugglers" box with the objective of luricating the bearings or replacing the motor? Thanks!
All the Best, Greg |
Bentley's repair manual (section 870) will give you general instructions; it's so straight forward that little or no specific instructions are required. Remove two support brackets, four spring clips holding the two halves of the evap box together, disconnect the wiring harness in two places, CAREFULLY pull out the thermo capillary tube, and you're there. Sometimes the spring clips can be a bugger to remove and replace, however, if you drop them, they can easily be found by removing the inlet air side of the evap box (inside the car, on the passenger side) and use a small magnet if necessary to retreive them.
Marc Morrison 1964 356C coupe '89 911 coupe 2008 Honda Accord 2008 Ford Ranger |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
I think this motor is serviced just like the footwell blower motors. pm me as needed. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 08-07-2010 at 05:42 PM.. |
Thanks for the info re 1985 AC blower motor. I'll look for the items re motor lubrication. Gerry thanks for the offer to contact you for additional help if needed.
Throw it on the ground!
Anyone here with a 1986+ done a Kuehl Wirblesturm "Hurricane" evap motor upgrade? Motor lube info here A/C Blower Motor - Mating call of the whales??? This method of box clip removal can only be done with the entire evap box out of the car. A/C Evaporator box clip tips
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
evaporator blower removal
FYI: If you are removing the whole evaporator housing remember to take passenger side floor board out and remove the resister pack (I think it's called) or you won't be able to pull the evaporator out of the smugglers box. The resister pack has 4 screws holding onto the floor. Once you remove this you will be able to pull the evaporator out with no problem.
