Remove spark plugs from hot engine?
Is it advisable to remove spark plugs from a hot engine? Anything wring with re torquing them in hot heads?
I'd like to check my plug color immediately after a nice stretch of high revs. For some reason I am remembering some old advice against removing and reinstalling plugs in a hot engine.
1973 Coupe Projekt X (AKA bunch o' boxes full of parts) |
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
78 in a '71
On glide path...... 1971 911 T Targa 2013 Ford Fusion Titanium AWD 1982 Volvo 245, 1996 Ford F-150 |
Did you actually read it?
Why dont' we open the antiseize-no antiseize debate again whilst we're here?
78 in a '71
I scanned the whole article, missing that sentence (and probably others). My apologies.
The article states not to install when hot, but does not say anything about removal. Since the aluminum expands when hot it may be easier to remove them.
Ed 1973.5 T |
Problem is , if you want to get going immediately you've got to put 'em back in hot! Or if you are like me and live at the top of a long hill , just drop into 2nd and scream up! After a good cuppa , wander back out and put plugs in again, cold.
Tazzieman, I've been doing exactly what you said above and will continue to do so I guess. Unlike the anti-seize debate (which isn't going to do much harm either way), I'll play it safe.
Why ? Burning your hand is not fun "
The drag guys do it but on ford or chevy its way easier . There not gonna change while it cools |
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 06-28-2013 at 10:22 AM.. |
It is my understanding that since the demise of leaded fuel and the crazy additives in fuels today, reading plugs does not tell you much.
Those fuchers get really hot, and it's not like it's easy to get them threaded back in when cold either.
+1 on a wideband tester sensor. I welded in a second bung in my bypass pipe. That's how I check AFR. Why risk cross-threading and/or burning your arm/hand/fingers/forehead/ eyeballs on that hot motor. |
I broke down and bought a used wide-band on eBay today. Figured it wasn't worth screwing up the heads. Also, the fine art of plug reading is pretty much over given today's gas.
Thanks for the input.
1973 Coupe Projekt X (AKA bunch o' boxes full of parts) Last edited by kugelfischer; 06-28-2013 at 06:10 PM.. |
Chain fence eating turbo
I would not pull or install plugs in a hot engine nor put anti-seize on a plated thread spark plug.
