....depends how far into the carpet the right foot is....
![]() Round Barber, here two weeks ago, just above the top white mark. And she was loving every minute of it.
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
Rescuer of old cars
Yup, I know that. I'd just prefer the look of numbers, not hash marks. I agree that the gauge is, well... just a gauge. Can't expect it to be 100% accurate. I figure it's more informative than the oil level gauge, but not by a lot.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
So, I can't tell if some folks just get crazy with oil temps for no good reason. I have to change my oil about 3k miles since I go from summer to winter weight. I should get an analysis and let that be my guide, I guess. But, on the other hand, if I have something wrong I'd like to get it fixed.
88 Carrera - Venetian Blue 2002 Audi S4 Avant (KIA) |
Reiver
I doubt there is a problem you'll find. If you change your oil regularly shouldn't be an issue.
If you want to control your temps better then have the fan switch (front right radiator) relayed to a switch in your cockpit so you can engage it at lower temps. |
Banned
Brando
///////yeah good numbers\\\\\\\\\
Wish I could duplicate.
Turbo powa! 1977 911s. it's cool |
One thing I like to do is pop the engine lid when I get back to the garage. I think it cools much faster and there is less prolonged cooking of wires and hoses
![]() Franny
White '86 Carrera Cab "Shamu" |
Kurt |
RETIRED
Pull the gauge, have it calibrated and an overlay with numbers. North Hollywood Speedo will do an exchange. They will likely send you one, core charge/exchange.
Palo Alto has a good rep, never used them.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I've got a IR temp coming in the mail. Going to make sure my engine mounted thermostat is working, and that the gauge is reading correctly in general. It seems to be since the gauge correlates well with the 240 degree OE sensor for the fan, and the 210 degree sensor I have in there now. But, it'll be good to know for sure.
My 87 was running temps like yours. Rebuilt external thermostat and temp needle rarely gets past the first tick. Feel the oil line past the external oil thermostat going to the front of car, feel oil lines on engine side of ext. thermostat. Should be hot past ext. thermostat after it opens. Somewhere around 186 deg? Mine weren't getting hot past the ext. thermostat, got warm but not hot. Not saying its your issue, but it fixed me up.
my '87 911 runs normally right between the 180 and 210 markings. However, as it's been brutally hot here in NJ, it's been running more at the 210 mark.
