'86 carrerra O2 sensor
can someone point me to correct O2 sensor for my stock carrera - can't get at car right now..
'86 944 '86 911 07 cayman Last edited by dcarlson; 03-01-2013 at 03:11 PM.. Reason: bad idea |
our host parts list does not seem to target it - will this work
Bosch W0133-1604453 Oxygen Sensor | Auto Parts Warehouse
'86 944 '86 911 07 cayman |
you can just use a generic sensor $15 at pep boys and splice the wires.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Go-Kart Mozart
Bosch 13913 for '86 Ford Taurus worked for me. Just splice in the wires. Crimp not solder. Can be had at just about any FLAPS for less that $30. -J
I used the Taurus one, also...
Dave Black 1985 911 Carrera M491 |
thanks for responses/suggestions - just trying to get one that will be direct fit and not require splicing, etc. Suppose I'll have to get old on out first to match it up to something
Pelican does list it:
Bosch O2 Sensor for 911 (1986-89), 911 Turbo (1986-94), 911 C2/C4 (1989-94) But it's $134.50. I spent about $100 less by going to Autozone and picking up the aforementioned Bosch 13913 for an '86 Ford Taurus and splicing it into the old connector. I used weatherproof butt connectors to connect the wiring and then wrapped the whole thing up tightly with electrical tape. |
thanks, appreciate the suggestions. Hope it has some positive affect on poor running motor I've been trying to sort..
Caveman Hammer Mechanic
BTW, what is the problem? Poor running covers a huge spectrum. eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
well... found a vac hose off at back bottom of throttle body - re-connecting helped a lot but still have a missing/hesitation when acceleratlng..most still telling me I likely still have some vac leak(s) . this came on suddenly with no deterioration in motor performance over time...have done wires, cap, rotor. fuel filter, air filter, DME, new coil. will try some new plugs I guess but will be tough for mew to get at them. . Starts, runs, idles good but just when accelerating .. it is obvious that something is holding motor from taking off normally..
'86 944 '86 911 07 cayman Last edited by dcarlson; 03-06-2013 at 02:14 PM.. Reason: erroir |
OXYGEN SENSOR, HEATED, 4-WIRE -- 16.93 in. wire length; Threaded-in type; Includes male connector and easy-to-follow instructions; Quality tested to ensure efficient fuel combustion; A high quality, OE replacement oxygen sensor; Features stainless steel shell, hex nut, shield, Teflon-covered insulated wires, high-temperature rubber internal and external seals, and threaded tube coated with anti-seize compound; Helps reduce harmful emissions; Backed by 1-year, unlimited-mileage warranty.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
86, not 96.
