83 911 SC engine quits when warm
I have a 3.0 with 155,000. Good shape but has started a bad habit. Cold it starts quick but sputters until warm. When warm it idles with occasional misfire. After 30 minutes of driving or idling it begins to sputter, backfire and quits. Starts up with little issue and then runs rough for a few minutes. Then runs fine until the next bout with sputter, loose power, backfire, and quits. Fuel full, oil and temp in normal ranges, checked as many vacuum lines (as I can find). Any ideas as where to start my search? Thanks in advance.:(
Could be incorrect control pressure. Do you have fuel pressure gauges?
Could be air box leak. Do you have a pop-off valve installed? Control plunger could be sticking or binding. O2 relay could've gone bad. If it started all of a sudden that would be my guess. Could also be a few other things like leaking injectors but we need to start with the basics. |
Quick test for vac leaks. When the engine is warm (between bouts), remove the oil filler tube cap. If the idle changes, that is a good sign. If the idle doesn't change that means you have a significant vac leak. If you'd had a backfire, it could mean the airbox has a crack.
sounds like it is running lean.
tighten all vacuum type connections |
3.0 quits when warm
Have pop off valve, plunger feels free, moving easily, engine idle changes when removing oil filler cap. I do not have pressure gauges, where can I find those? I will look up how to check O2 relay. Not finding any fuel leaks. Any advice?
I would check the fuel supply. Could be a good idea(and cheap) to replace the fuel filter and perhaps cut it open to see if you can find traces of water and debris of some kind. I had a friend who had this kind of problems that kept coming back. He had a very small hole in the fuel filler line where dust and water came in and made the engine run like crap. Very difficult to find. I guess a cold engine will have less problem due to more fuel being injected making the problem less obvious
would check the Warm Up Regulator,
In my car that was the problem for warm idle also |
You can get the fuel pressure gauges from Pelican or Amazon. You can go ahead and order the O2 relay. If you don't need it now, you eventually will. Good insurance to have. It is a little cube under the passenger seat.
When I bought my '83 a couple of years ago I had several issues. Weak spark - changed plugs, plug wires, rotor and cap. Changed fuel filter. Ran a can of BG44k through the fuel. Also the cold control pressure was too low. It could be a few things, so let's be methodical. Tony (boyt911sc) and some of the other experts will chime in too. There are a few things tests that can be done in the meantime before you start swapping parts. Some things to check and report back: - With the key ON but the engine not started, take off the air box cover. You should NOT hear the fuel pump running. Reach in and push up on the pressure plate arm for 1 or 2 sec, but no longer. You should hear a distinct buzz. That is the frequency valve. Report back. - You can't really check the WUR without the gauges but you can check the resistance of the bimetallic strip using a multimeter. You should have a type -090 on an '83. Pull the electrical connection off the WUR and use a pair of alligator clips to connect to the metal spades on the WUR side. The resistance should be around 25-26 Ohms. - Unplug the O2 sensor and see if it gets better. Be advised the O2 sensor connection is really brittle and it could break completely when you mess with it. It's located underneath the fuel filter on the left side of the engine compartment. - Fuel delivery could be a problem. Could be fuel pump, check valve or leaky injectors. Hard to diagnose unless you have gauges. You can do the injector test by pulling the injectors and putting them in something like baby food jars (just small clear containers). You can fire them by pushing up on the pressure plate arm. They should not be leaking and should spray a fine mist. |
Might also be a leaking cold start valve. That would make the engine run excessively rich and it will likely idle rough when cold or warm. The rough idle would likely get worse as the engine warms up, but that doesn't sound like what yours is doing.
when he lifts the plate he will hear the fuel pump will he not regardless of if the frequency valve is working ..
I would also have a look at the plugs and note their condition .. as far as the pop off valve goes they are more trouble than they are worth, make sure it is not leaking past the epoxy and the lid closes and seals securely. Also when you say backfiring do you mean through the intake or the exhuast ? |
Good point on the pop-off valve. If it is not closing properly or the epoxy around it is cracked it could certainly be sucking false air. They are cheap insurance against a blown air box but that's all. When I first bought my car I would hear it pop on a regular basis. It was as if that's how the car is supposed to run. Lot of myths out there... |
Reporting back on fuel pump check
OK key on, could hear high pitch whine, lifted pressure plate and heard the fuel pump kick fuel into the system. Ordered an O2 relay and new fuel filter. Have to wait until evening to run some of the other checks. Those little fuel pressure gauge sets are not a cheap tool, I am going to check with a few friends to see if anyone has one I can borrow first.
Thanks, Mike Quote:
When you say high-pitched whine, let's make sure we're talking about the right thing. When you push up on the pressure plate there should be a distinct buzzing sound coming from in front of you. If you did not hear that buzzing it means the FV is not working as it should. If you hear more of a whirring sound (I'm not sure how else to describe it). That is the sound of the fuel pump. You should not hear it running with the key in the ON position. If you have skinny enough arms, take your left arm and reach in and try to feel around on the backside of the engine for a loose wire. The connector will be a blueish green color if you can see it with a mirror and flashlight. That is the pressure plate sensor and it should be plugged you. You may have to fumble around blind but you will feel where it plugs in. You should definitely have it plugged in for safety's sake. It is designed to cut off the fuel pump in certain accident situations. People usually describe the CDI as being a high-pitched whine. I have a Permatune instead of the original Bosch. The Permatune CDI doesn't make that sound so I can't tell you what to listen for there. |
I forgot to ask an important question! Is your car a US or RoW model?
CIS troubleshooting..........
When you lift the AFS (airflow sensor) plate with the ignition @ ON position, the whirring noise/sound is NOT THE FP!!!!!!! The FP is located at front of the car unless you have a bad FP to make that loud noise. The noise is generated by the 6 fuel injectors spraying fuel simultaneously. Go back to the car and try it yourself.
Tony |
It is US model. I ordered new fuel filter and O2 relay, checked the air box and pop off. I did find some questionable vacuum lines. Went to parts store to pick some up. Just as I pulled in the car lost power, began missing, exhaust smelled very rich. Came back out of store car started right up and repeated the missing and rich smell about 10 minutes later. Parked it at the office, try again when I go home. Ordered parts will be in on Friday so I will get those swapped in and see what happens from there.
The spray sound I hear, after a second or two I hear the fuel pump (?) kick in. I believe the high pitch whine is the Bosh CDI. Comes on as soon as I turn on the key. The one thing I keep coming back to is the car runs great during warm up. 10 to 20 minutes later it starts the rough running dance. Cool down while at lunch, starts and runs great. I am currently doomed to 10 minute road trips :(
Parts received and replaced. Partial success but still quits.
Received fuel filter and O2 sensor relay and installed them. Replaced some 4mm vacuum lines while I had it apart.
Items checked are vacuum lines and connections, remove oil filler when running, engine reacted, pop off valve o ring in place and valve working smoothly, air flow sensor plate centered, operates smoothly, closes flat. Pulled and cleaned all contacts on ignition relays and connections just for fun. Last tune up was 5/2012 with about 1000 miles on the tune up. Started it up, ran smooth went right to 900 rpm. That is the first it ran that well cold. Let it sit and idle. At the 20 minute point (engine now warm) it began to miss, then sputter, then at 21 minutes die. Looks like you guys solved one problem (rough running when cold) but I need to figure out where to go next. I like the methodological approach but could use some thoughts as to where to go next. I am taking it in for a valve adjustment by a Porsche mechanic in a couple of weeks at his suggestion. I would do it my self if I was more confident in what I am doing, but kind of saving him for my back up plan as I would like to learn this box engine myself. This appears to my uneducated mind to be heat related. Engine runs great until it gets to temperature then the dance starts. Cools down for a few minutes and away we go again until the temp (I presume) comes back up to the shut off the power temperature. Any path to follow would be great. :confused: |
Micheal,
Fuel pressure test is going to tell a lot. Too high or too low control pressure will make the air-fuel ratio incorrect, causing a rough idle. Here is a write-up I did on how to do the test and other troubleshooting. http://forums.pelicanparts.com/porsche-911-technical-forum/758788-cis-troubleshooting-dummies.html It is a work in progress. Glad we got one thing resolved. Let's get the next one! :) What is your engine temp reading when it starts stumbling? One thing is that the injectors or the cold-start valve (injector) could be leaking. But it seems odd that it only starts after 20 min so I'm inclined to think that is not the issue. The ECU under the passenger seat could be suspect. It is responsible for adjusting the air-fuel mix between idle and WOT. I'm wondering if your CDI box might be in the process of dying. I don't have a Bosch so it's hard for me to say. Maybe some others could chime in. If it is the CDI, you have 2 choices: get it rebuilt or do the MSD upgrade. Use the search function and you should find plenty of threads on both. When it starts to stumble, you might try testing the spark. You can use a timing light and move the inductive connection from plug to plug to see if the light is firing. Double check the timing while you're in there. If you're not getting good spark, it could be plugs, plug wires, distributor cap, rotor, or coil. But let's not get too far ahead of ourselves. |
Fuel pressures
Tirwin,
At long last I received my pressure check gauge. From your write up (nice job, thanks) the WUR Ohms were 30 at 86 degrees. The system pressure was 70 psi at 74 degrees. The Warm control pressure was 52 psi at 84 degrees (that looked high). The operating pressure was 45 psi at 84 degrees. Only ran it for about 5 minutes as I developed a leak. Waiting for a seal so I can get residual pressures. With the leak it dropped to 20 psi within 30 seconds so no 5, 10, 15 minute check. Cold start was always pretty quick (bump the key) but it did run rough for 20 or 30 seconds and then smoothed out. When I get the leak fixed would it be of benefit to leave the pressure gauge in place and let it idle until it starts it's dance and quits? Any other thoughts? Mike |
Micheal,
System pressure should be between 65-75 psi so that looks ok. The warm control pressure should be between 49-55 psi. I didn't see your cold control pressure. It should be around 1 bar or 14.5 psi. |
Micheal,
System pressure should be between 65-75 psi so that looks ok. The warm control pressure should be between 49-55 psi. That looks ok. I didn't see your cold control pressure. It should be around 1 bar or 14.5 psi. If you are calling the operating pressure the cold control pressure, then you are very high at 45 psi or ~3 bar! Can you redo the test to verify when you get your seal? When you open the valve after doing the system pressure test, you should see the pressure drop to about 1 bar. Once you plug in the electrical connection to the WUR, you should see the pressure rise slowly to 49-55 psi in 3-5 minutes. Focus on that before worrying too much about the residual pressures. If your cold control pressure really is that high then we have found a problem. Next will be sorting out why it is so high. |
Cold Pressure
The cold pressure is around 10 psi. Hard to tell as I developed a small leak. The 45 psi was with the engine running but not warmed up as the leak prevented any more. I will re do the test next week end. Parts should be here Friday.
Thanks |
Fuel pressure check........
Micheal,
Now that you have your fuel pressure gauge kit, do a test when the engine is totally cold. Like after sitting overnight. Check the cold control fuel pressure versus time. For example: start, 30 sec., 60 sec., 90 sec........etc. until the control pressure stabilize (4 mins. max.). and no need to run the engine. You could do this test by just running the FP. The objective of this test is to see the behavior of the cold control fuel pressure, deflection of the bi-metallic spring, and the over-all characteristic of the WUR. The slope of the chart for this data is not exactly the same as when the engine is running but the correlation is very close. BTW, what's the number on your WUR? Do you have a USA or RoW car? Keep us posted. Tony |
Parts in and rerun pressure checks
Reran pressure checks: 75 degrees +-
WRU 30 Ohms System pressure 68 psi (was 70 at 85 degrees) Cold control pressure 2.2 bar Warm Control pressure : 1 min 2.8 bar 2 min 3.0 bar 3 min 3.4 bar 4 min 3.6 bar 5 min 3.6 bar Residual pressure at 30 minutes 20 psi, 60 minutes 10 psi I found it interesting on your comment about the CDI. I do remember it got wet a few months back. It took a while to dry things off but they may have not been properly dried. As the engine gets to temperature is when I get the problem. Is there a test for the CDI or do I need to just upgrade. Hate to do it if that is not the problem. Any other thoughts? Mike |
Micheal,
I'm traveling and it will be late tonight before I can look up the numbers on the cold control pressure but it looks high at 75 F. That would mean a leaner mixture at startup. I think you're warm control and residual pressures look good. I'm thinking through what else would be going on after the engine warms up. Let me noodle that a bit. On the CDI, I seem to remember reading about people having CDI failures after the box warms up. The problem with testing it is you'd have to bench test it under similar circumstances to recreate the problem. Might be easier to see if someone with a known good one would let you borrow it and try it out. |
Evaluating CDI & ECU.........
Mike, If you have the technical ability to do the electronic evaluation for CDI or ECU, would be great. There are several members who do this for a living. But for most, we are limited in doing such tests. Due to this limitation, I rely on using known good unit and do the test (switching parts). http://forums.pelicanparts.com/uploa...1374456239.jpg http://forums.pelicanparts.com/uploa...1374456286.jpg Tony |
Micheal,
Check out this thread... It does sound similar to your problem. http://forums.pelicanparts.com/porsche-911-technical-forum/551529-what-could-have-caused-my-78-sc-stall-highway.html In particular check out the post by ischmitz. What type of CDI do you have? The two most likely are Bosch and Permatune. |
Checked the article, you are right it does sound similar. Spent some time trying to find one to "borrow" with no luck. During the search my problem modified to starting and running good. Went past the usual 21 minutes. I decided to drive it to work. First few minutes were fine then it lost power, started to backfire and cough then smoothed out. Repeated the process all the way to the local parts store. Out of frustration I picked up a MSD with coil and have it partially installed now. So far the install is easy spending more time cleaning up wire runs and looms than necessary. On a business trip right now so can't finish it until Monday or Tuesday. That is when I find out if I did a stupid thing or the little CDI was flaking out all along. Is there a plug that works best with the MSD, and how do I tell if I have solid core plug wires or not? I will need to get these ordered from Pelican soon so I can drive it before the snow falls.
Typically, the OEM "Beru" wires were sort of gray color with a fabric type jacket. Something like this: http://www.pelicanparts.com/catalog/images/Connect-Images/108533613-M47.jpg
Most of the solid core wires I'm familiar with are covered with a red rubber-like jacket, but I'm sure there are exceptions. Magnecore is the most popularly used. Pelican Parts - Product Information: PEL-MAGN65-83 Good additional reading: http://forums.pelicanparts.com/porsche-911-technical-forum/522684-resistorless-rotor.html |
Thanks, mine are dark grey with stainless steel grounded shielding. Would hate to loose the look and they are not that old.
Correction... the "fabric type jacket" I speak of above is actually the grounded stainless steel jacket you speak of.
Ok at long last all parts have arrived. The MSD install went well and was straight forward with the exception of one point I confused myself on. I used the white wire from the MSD and connected it. However I do not think that is correct. Doesn't the 83 3.0 have magnetic pickup? If so, I am not sure where to connect up the magnetic pickup harness from the MSD to. Any help? Thanks.
"the white MSD wire is connected to the main green wire in the connector. This wire should come from the distributor and is connected to the magnetic pickup or points."
Excellent read: Pelican Technical Article: Installing an MSD Ignition Unit - 911 (1965-83) - 930 Turbo (1975-83) |
Thanks, I did get it right, just second guessing myself. Been a lot of years since I had time to work on engines. Why I am at it I am replacing the plugs, rotor, cap, (wires look good and they only have a few miles on them). Anyone know if my old Snap On timing light with work with MSD or maybe my Equus 5568?? I never thought about difference is signal when I decided to do this little project.
Your old Snap-On analog light is the ticket. Save the fancy Equus 5568 for your modern cars.
Moving forward
Sorry for the delay, been traveling for 3 weeks. Engine temp was in the normal range. I did some reading on the flaky CDI idea. I am experiencing many of the same issues. So with that under my belt I bit the bullet and started to install a MSI 6 AL. All went well following the combination of instructions from the write up here and the MSD instruction set. One issue I now have is I believe my distributor is magnetic pick up (no points). MSD says to use the purple and green for magnetic and the white for points. The tech write up says to connect the white from the MSD to the green from the harness. I did that but no work. Any idea which is correct? The red led never even flashes. Ground tested and solid, large red to full time power, small red to keyed power, grey to tach all test properly. New plugs set at 1.34, new battery, new cap and rotor. I feel like I have all the parts just the wrong combination in the final wiring. :confused:
System test: Key on no LED flash. Turn over ignition, no LED flash no spark, didn't do for long as fuel injection was pressuring the gas to the fuel system. Tested all wires for proper power at proper time. Not sure where to go next. |
Try this if the white wire doesn't work:
The dizzy's green wire is actually two wires. Confusing.. yes... I know. Great read: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/681453-930-distributor-signal-wire.html |
Micheal,
Could you post the identification # of your WUR? What's the value of the heating resistance (Ohms)? Keep us posted. Thanks. Tony |
| All times are GMT -8. The time now is 04:18 PM. |
