LinkBack Thread Tools Rating: Thread Rating: 19 votes, 4.74 average.
Charles Freeborn's Avatar
Pros - cons on removing or bypassing the Decel Valve? Mine is showing all the signs of improper operation (high idle, slow return to idle). My guess is the over rich condition when lifting would cause backfire - is that all? Is it a serviceble part?
Thx.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 03-20-2016, 07:12 AM
Everything I've read on this decel valve condition is that you have to squish the valve by 1mm with a pair of channel lock pliers or similar. There was a Porsche bulletin on it too.
Old 03-20-2016, 08:50 AM
I'd like to learn more about this. Is there an online version of the service bulletin?
Thx
1972 914/4 Race Car
Old 03-20-2016, 09:06 AM
El Duderino
tirwin's Avatar
My decel valve has always been bypassed.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 03-20-2016, 11:30 AM
I'll give it a go. Thanks.
Old 03-21-2016, 05:53 AM
Thx
Also interested
on the road...
Old 03-21-2016, 09:23 AM
Yep here it is - it's a one page tech bulletin. I have not tried this.
Old 03-21-2016, 03:02 PM
thank you!
on the road...
Old 03-21-2016, 03:10 PM
Looks like a later generation (3.0) CIS than my '74 has. Interesting read nonetheless.
-C
1972 914/4 Race Car
Old 03-21-2016, 03:26 PM
Hi Charles - I *think* there is a screw on the top that you can use to adjust the older style valve.
Old 03-21-2016, 03:56 PM
What you will need:
1) a set of CIS fuel pressure gauges
Hello, I'm stuck at your 1st point!
Can anyone point to a store that sells these gauges? I am in the U.K and it's not obvious what to buy, thanks.
Old 05-23-2017, 11:38 AM
Fleabit peanut monkey
Bob Kontak's Avatar
But this book and read it with extreme enthusiasm. Especially the k-jet chapters.
https://www.amazon.com/Bosch-Fuel-Injection-Engine-Management/dp/0837603005/ref=sr_1_fkmr0_1?ie=UTF8&qid=1495568727&sr=8-1-fkmr0&keywords=charles+probst+Bosch+continuous+injection +systems
I am assuming you don't know how to use the gauges, correct? Read the book. You will ask better questions.
Here is an Amazon UK link to a pressure tester that will work fine with CIS.
https://www.amazon.co.uk/Jago-BZDP01-Steel-Pressure-Tester/dp/B00A78CCHY/ref=sr_1_1?ie=UTF8&qid=1495569045&sr=8-1&keywords=CIS+fuel+pressure+tester
1981 911SC Targa
Old 05-23-2017, 11:53 AM
Thanks Bob, that looks like the right set. Ordering now!
Old 05-23-2017, 10:52 PM
subscribed
Old 05-24-2017, 04:42 AM
Decel valve ('74~'79).......
-C
Charles,
You have the earlier type decel valve which is adjustable. Use a hand held vacuum pump to adjust and calibrate the valve's opening pressure (15"~ 22" Hg). I like the old one better than the newer version.
Tony
Old 05-24-2017, 04:56 AM
I had high idle problems, slow rpm drop off and many other poor driveability issues. It made the car unpleasant to be in, when the revs climbed to 2000 while sitting in traffic, or gear shifts were botched because the revs didn't fall.
I disconnected the decel valve and put a golf tee in the vacuum line, as recommended here. Instantly fixed all these woes. PO had spent bulk cash with clueless mechanics trying to sort out the issue.
The only thing I'm planning to do further is to make up a proper dead plug for visual purposes rather than having a golf tee hanging off the side of the engine. I'll never reconnect the valve, and won't bother trying the crush method above.
It is a pollution control measure and does nothing to improve the driveability of the car, even when working properly it deadens throttle response. The only downside is the occasional pop and crackle in the exhaust on long throttle-closed downward descents. The same as you would get in a carb equipped car, because the high vacuum, fuel rich mixture is igniting in the exhaust.
Old 05-26-2017, 03:40 PM
Great reference thread Tim, thanks for doing the hard work.
Just thought I would share a couple pictures of the switch I made and the hookup at the fuse panel since I don't think I've ever seen the actual hookup and you know, the whole thousand word deal!
I made my switch with a very long length of fairly heavy gauge speaker wire (had it handy) so that I could operate it from the engine compartment- seems to me if something went wrong I could immediately shut the pump off as well as not knowing if something was going wrong as I made my way to the back of the car.
Rutager West
Old 07-09-2017, 08:41 AM
Bob Kontak's Avatar
Outstanding, rwest.
1981 911SC Targa
Old 07-09-2017, 09:32 AM
bugstrider's Avatar
Subscribed!!!
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 07-17-2017, 09:13 PM
Still here
pmax's Avatar
Collecting the charts here
1981 SC CIS - low idle - wrong WUR?
Old 07-21-2017, 11:38 PM
