matt gineo's Avatar
Clamps for Intake Runner Boots
I can't find anyone who carries the clamps for the Intake runner boots on my 76 2.7 CIS. Will standard stainless steel hose clamps do the job?
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 07-08-2013, 01:31 PM
ROW '78 911 Targa
timmy2's Avatar
Try aircraft spruce for the non cutting variety of hose clamps.
Old 07-08-2013, 02:04 PM
ROW '78 911 Targa
timmy2's Avatar
Or these ones from our host!
Pelican Parts - Product Information: 999-512-267-02-OEM
Listed as 80-83 in the catalog but when you go to the more info page and look at drawings it shows your year.
Edit: NLA.... DOH!
Old 07-08-2013, 02:09 PM
Senior Advisor
James Brown's Avatar
any clamp will work fine. it's a hose on a pipe for god sake
08 Cayenne Turbo
Old 07-08-2013, 02:17 PM
matt gineo's Avatar
Sorry I asked mr Senior Advisor I have not seen them yet so I didn't know if there was anything special about them. Next time I'll check in with you before I ask any more stupid questions.
1962 356 C- sold
Old 07-08-2013, 03:43 PM
ROW '78 911 Targa
timmy2's Avatar
Ouch!
Can't we all play nice...
Personally, I would look for the non cutting variety so you don't get a vacuum leak in a couple of years.
Old 07-08-2013, 03:52 PM
matt gineo's Avatar
Originally Posted by timmy2 View Post
Ouch!
Thanks Timmy, I appreciate the constructive advice. I've already located the aircraft clamps per your suggestion.
1962 356 C- sold
Old 07-08-2013, 03:59 PM
Make sure you get ones that be tightened with a screwdriver. They are a bear to get at in the car if you need to and I can't imagine using the ones with a wing nut/thumbscrew thing.
Kinsley
1980 SC Targa - MS2, EDIS
Old 07-08-2013, 04:03 PM
matt gineo's Avatar
Thanks. good advice. These are the ones that I bought from McMaster Carr. I wouldn't want to take everything apart again because the standard hose clamp cut into the boot and caused a vacuum leak.
Stainless Steel Smooth-Band Worm-Drive Hose and Tube Clamps
Choose these clamps when you want an economical alternative to Type 316 stainless steel. Clamps are reusable and have a smooth band with rolled edges to prevent them from cutting into hoses and tubes. They’re ideal for use with silicone hoses and tubes. The band is 3/8" wide and 0.024" thick. Temperature range is –40° to +350° F. Clamps meet DIN 3017.
Type 430 stainless steel clamps have a Type 430 stainless steel band and housing and a zinc-plated steel screw. Tighten with a slotted or Phillips screwdriver, or a 9/32" (7 mm) hex nutdriver. Torque is 20 in.-lbs.
Type 304 stainless steel clamps have a Type 304 stainless steel band, housing, and screw. Tighten with a slotted screwdriver. Torque is 26.5 in.-lbs., unless noted.
Note: When choosing a clamp, measure the outside diameter of your hose or tube with the fitting installed.
McMaster-Carr
1962 356 C- sold
Old 07-08-2013, 04:13 PM
Senior Advisor
well MATT, that sounds better, i will be standing by with bated breath.
08 Cayenne Turbo
Old 07-08-2013, 04:16 PM
Talking Clamps
James, you spelled "baited" incorrectly......
Old 07-08-2013, 06:56 PM
Banned
Nope -
World Wide Words: Bated breath
Old 07-08-2013, 06:59 PM
How many intake clamps do you need?
Matt,
Sent me your address and I'll have them shipped to you. I'll be home tomorrow after being away for 4 weeks. How many clamps do you need? Please advise.
Tony
Old 07-08-2013, 07:27 PM
Senior Advisor
see, i never make a mistaik
08 Cayenne Turbo
Old 07-08-2013, 10:13 PM
clamps
James, I stand corectid.....
Old 07-09-2013, 09:24 AM
