Senior Member
Looking for AC Shop recommendation in Richmond, VA
I'm finally replacing all of my AC components on my 1982 SC and looking for an AC shop with experience charging older Porsche AC systems for the first time...any recommendations?
Thanks in advance, Olivier
Olivier Hecht 1982 911SC |
pm sent
I'm in Chester, redoing my AC system that was originally installed in 2005 using a combination of PerformanceAire and Kuehl stuff. Doing myself. We might conspire on some DIY and share some Megasquirt tales also. I should get my last two lines remade and in hand by Thursday and install and charge this weekend.
Brian |
Senior Member
Thanks, Kuehl, I will send you an e-mail.
Thanks, Brian...I might be on a similar timeline if I can get my new front condensor in time...I don't think I really need a new one, but the old one was just so bent and bad looking that I couldn't bear to tie it in to what will now be a brand-new system when it came time to hook up the hoses... I'm also definitely up for sharing MS info...I've got mine to a "stable" point, but there's probably a lot more I can do with it, especially on the timing side with EDIS. I need to find a good dyno place to tune that, I think. I've also got an engine rebuild in my near future, so I know the whole tune will have to change with that... Olivier
