pls help more hose and plug
hi can anyone tell me what does those plug and wire do . and also the last photo of the hose where should connect to . thank you
Vacuum port
The vacuum port in the left side of the air box is where the hose for the power brake hose connects. It (the brake hose) goes from there to the left front corner of the engine compartment. Should be easy to find. It (the hose) will probably have a "Y" in it to allow for connecting another vacuum hose that runs behind the CIS.
The wire looks like it might go to the plastic box the other arrow is pointing towards. You should be able to look at the connector inside the box and tell if they will mate up. Hope this helps some.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
thanx for reply . i will check it
