krshome's Avatar
DME ground where?
Can someone help me find the main ground wire for the DME on a 1988 911 Carrera coupe 3.2 pictures are worth a 100,000 words. Thanks
Old 09-12-2013, 12:59 PM
aj88cab's Avatar
According to the Bentley Manual there is not a single ground conductor, there are 5 (pins 5,10,16,17,19) and the ground point for these is the ground post on the #1 intake runner in the engine compartment. Sorry no picture, but you can't miss it if you take a look.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 09-12-2013, 01:13 PM
Go-Kart Mozart
JAR0023's Avatar
+1 Unless you have removed your aux fan you'll have to peek around the duct work on the left side of the engine. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 09-12-2013, 01:25 PM
krshome's Avatar
Is there a ground closer to the DME where as to kill the power to the DME?
Old 09-12-2013, 01:42 PM
An alternate plan is to kill (open) the source wire to the DME with a switch.
Sherwood
Old 09-12-2013, 02:03 PM
krshome's Avatar
Sherwood
Source=hot wire?
Old 09-12-2013, 02:40 PM
Source=hot wire?
Yes.
Source = hot wire = 12VDC
Consult a wiring diagram to be sure it's the correct one.
Old 09-12-2013, 02:52 PM
RETIRED
Joe Bob's Avatar
Brown wire.....ground.
2012 ML350 3.0 Turbo Diesel
Old 09-12-2013, 03:24 PM
Go-Kart Mozart
JAR0023's Avatar
hidden kill switch ideas for 84-89 cars
86 Carrera
H. L. Mencken
Old 09-12-2013, 03:37 PM
steely's Avatar
Source=hot wire?
power comes in on pins 18, 20, & 35 from the DME relay.
Kill the relay, kill the DME.
Buy a Bentley, now.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 09-12-2013, 03:44 PM
steely's Avatar
Dan
Venetian Blue
Old 09-12-2013, 03:46 PM
Chain fence eating turbo
The Bentley has lots of wiring diagram issues for the C3.2 beware.
The worst discrepancy is the crank bolt torque. I nearly chunked my crank pulley because I used the torque spec given and it was 50% under torqued.
Old 09-12-2013, 04:14 PM
steely's Avatar
Crank bolt torque has zero to do with DME I/O, but I think here is a point made there.
Best to verify against the 3.2 Bosch schematics like I did - and verify torques elsewhere (when that subject comes up).
PM me if you need schematics so you can verify yourself.
Watch out too for good info instead of vague warnings.
Dan
Venetian Blue
Old 09-12-2013, 05:41 PM
krshome's Avatar
Thanks I'll pull my seat tomorrow and look for the brown wire going to the DME.
Old 09-12-2013, 06:00 PM
Diss Member
Quicksilver's Avatar
I would hazard a guess that disconnecting the ground when running would have a chance of damaging the DME.
If you want to kill the car put a disconnect on the crank sensor. It will stop sparking immediately.
To disable the car pulling one of them slightly loose works great.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-12-2013, 06:51 PM
Diss Member
Ground wire #10 = Cali emissions.
Old 09-12-2013, 06:53 PM
