Taking it apart is easy
Jerome74911S's Avatar
Originally Posted by Ronnie's.930 View Post
This "re use drained oil" subject reminds me of the "change oil at 3K miles debate". For some, it seems to offend their sensibilities to go more than 3K on oil, but I find 3K oil change intervals to be grossly wasteful to the point of arrogance.
I agree with the emphasis on how 3K intervals waste oil. Good oil in a car that is driven 'well', with today's additive packages need not be changed that often. I am happy to change mine annually. Better if you have luck with synthetic, which is intended to run longer.
Obviously some cars are driven in severe conditions, or poor oil is used in them, or both. There is no hard rule of thumb, but to change at 3K without consideration of the circumstance and product employed is wasteful of resources.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 07-17-2013, 05:46 AM
VW bug oil was turned filthy the minute you turned on the car after an oil change. It only held 2 and a half quarts. Tossing out 10 quarts of good oil is a waste. Just going in a smelly old motor. Most of these cars have already done their job going well over 150,000 miles. We are not talking about a Lamborghini here.
Old 07-17-2013, 06:23 AM
bodmin's Avatar
I like that Fumoto drain valve. I've often thought that rather than changing all the oil at say 6000 miles it would be better to drain a 2 litres of old oil, and add a 2 litres of new oil every 1000 miles.
That way the oil is constantly being replenished and always in good condition. The Fumoto valve would facilitate this schedule.
Just a thought
Old 07-17-2013, 07:05 AM
muck-raker
kidrock's Avatar
Why don't they have a Fumoto for the '84-'89 Carreras?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-17-2013, 10:48 AM
"They" being Pelican or Fumoto? Use your computer or phone?
Pretty sure the oil tank drain threads are the same as earlier 911s. The valve shown with the hose connection may not be in the Pelican parts catalog.
S
Old 07-17-2013, 12:03 PM
muck-raker
kidrock's Avatar
S
I should have been more clear, apologies. I only did a search on Pelican, which has the Fumoto for cars up to '83. I've also read past threads where other Carrera owners have been unable to find the Fumoto for their 3.2's.
I'll do a different search on another engine.
STONE
Old 07-17-2013, 08:10 PM
Reiver
Reiver's Avatar
Re using oil defined...Old Yeller, the home built special that would often beat the latest Ferrari's, often used re-used oil.
Old Yeller 2 - The Official Website of this Famous Race Car
The owner would go to other pit areas and ask for their freshly drained oil so he could 'freshen' his car....it was also part of the heavy psyche he put on other drivers...wide white tires, used spark plugs etc. but he often beat the pants off Maserati's, Ferrari's and any other comer.
Old 07-18-2013, 04:43 PM
