carrerarsr65
911sc case split?
trying to split cases 79sc, heres the problem pistons #2/#5 are still below the case spigot,long story short motor locked up tight!! i have all case bolts/nusts removed, the crank will not spin at all, need to get the pisons off before case split any ideas would be great!!!!!! cant get those c clips?
Old 07-16-2013, 07:31 PM
Chain fence eating turbo
Man, never thought of that. That's a tough thing to do. I'd post in the engine rebuilding section, one or more of the shop owners have probably dealt with this and have a good solution.
Old 07-16-2013, 07:41 PM
...and my blue mistress
mazing3's Avatar
can you post a picture of this?
Robbie
1976 Carrera3.0
1978 928 5spd
Old 07-16-2013, 08:21 PM
You probably jammed a piston (or two) up against the case. Try rotate the opposite direction. I never remove case nuts until pistons are out.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 07-16-2013, 09:03 PM
kodioneill's Avatar
Was the engine locked up before you started the dis-assembly?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 07-17-2013, 06:13 AM
T77911S's Avatar
why remove case bolts before pistons?
what about the timing chains. they jammed up in there?
post a pic
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-17-2013, 07:45 AM
mazing3's Avatar
If chains are off and everything else is done I don't see why you can't turn the crank the other way and "un-stuck" the piston. Which is probably really the rod anyway. Pop it with a rubber mallet and some common sense if you have to.
Unless why were you splitting it to begin with has something to do with this.
Old 07-17-2013, 08:08 AM
