frannyB's Avatar
Dumb question, but, for an 86 Carrera, the engine and tranny mounts are the same part number same part. Is that correct?
This post was auto-generated based upon a question asked on our tech article page here:
White '86 Carrera Cab "Shamu"
Old 07-16-2013, 02:23 PM
Nick at Pelican Parts's Avatar
If the part number is the same then they are the same mounts. The part numbers should be different though. Give our parts specialists a call at 1-888-280-7799. They can help you find the right part.
- Nick
schumicat's Avatar
yes
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 07-16-2013, 02:31 PM
Undocumented User
McLaren-TAG's Avatar
Yes they can be the same unless you want something stiffer and put in cabrio mounts for the tranny.
Old 07-16-2013, 02:34 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 yes, I have cab mounts engine and trans
'85 Carrera Targa
PCA/POC
Old 07-16-2013, 09:20 PM
