carrerarsr65
zinc plating
where can i get zinc plating (gold color) for my engine hardware , i live in springfield,ma 01108
Old 07-16-2013, 02:36 PM
ROW '78 911 Targa
timmy2's Avatar
Search the web for cadmium platers in your area and call them to see if they will do small quantities.
Old 07-16-2013, 02:56 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by timmy2 View Post
Search the web ...........
+1 but search on metal plating.
Cadmium plating is the correct material but it is harder to find vs yellow zinc plating due to environmental procedures/equipment that must be used for cadmium per EPA regs.
Yellow zinc is comparable in how it looks vs cadmium but I have no idea how it .lasts vs cadmium
1981 911SC Targa
Old 07-16-2013, 03:17 PM
Racer
winders's Avatar
Porsche used yellow zinc coated fasteners, not cadmium.
When did Porsche transition from silver cad plating to gold cad plating on 911's? [Archive] - Early 911S Registry
Scott
Old 07-16-2013, 05:14 PM
kuehl's Avatar
Zinc and Cadmium are naturally silver
The yellow appearance use to be provided by a yellow chromate dip afterwards (the world no longer likes chromates).
Cadmium holds up longer than zinc.
There are "newer" or should we say more environmentally preferred or required
coatings using zinc; referred to as RoHS or Restriction of Hazardous Substances Directive
There are plenty of platers left whom can help you,
Here
The cost to plate varies depending upon the quantity and method (barrel vs. hung).
We still have many of our products zinc as well as cad plated for certain applications.
PM if you need more help.
Griff
Old 07-16-2013, 06:00 PM
Bob Kontak's Avatar
Thanks for the link. That one dude was pretty adamant about "not cadmium".
kuehl - good info. Thanks.
1981 911SC Targa
Old 07-16-2013, 06:07 PM
kuehl's Avatar
Cad is superior, especially in salt environments and it lasts for ever, but true
the tree's don't like it. The issue with zinc on steel is it oxidizes. The oxide
absorbs moisture and accelerates the oxidation of the steel; catch 22.
Zinc on electrical connectors is a PITA as well, the oxide becomes an insulator
and ... no electrical flow. Oiy!
Bob, where's WwEsT ? lol.
Old 07-16-2013, 06:41 PM
BoxsterGT's Avatar
Porsche Crest
carrerarsr65-
Add your email contact to your name and I will send you the needed info. Or, email me. I don't do PMs as I cannot send photos.
Len
Old 07-17-2013, 06:23 AM
